How to program the SN761672A
I am positive it's the code tuning somewhere in space! I've already replaced the TA2003 receiver with a TDA7000 one, no reception, only the arduino and pc noise. The TDA7000 is also tunable and has been hooked to an analog tuner.
It can't be the code since i used it and it worked fine; i just programmed mine using your IF of 31.9Mhz and even with my filter of 38.9Mhz i still could receive several stations on the radio. Are you sure that the radio chip is in the right frequency or even oscillating?, because recently i've tried different LC combinations and with some of them the chip just refuses to oscillate. If you have a frequency meter you'll have to use a coupling loop to measure the frequency since the ta2003 is so sensitive that it will stop oscillating if you connect anything to the oscillator pin.
Thank you very much for your patience and support, I was about to give up without you. I wish you all the best. You're right, it's not the code. Now and finally I captured the 88-108 stations but the display doesn't show the right frequency. I have to work that out tomorrow.
I finally managed to modify the last code you posted to make it work with this tuner and show the right frequency:
//here is the code for SN761672A TV tuner, I'm assuming you using Arduino nano board.
#include <Arduino.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
#define clk 2 // rotary encoder clk pin
#define dta 3 //rotary encoder dt pin
int CurrentClock =0;
int PreviousClock =0;
uint16_t RF =2890; //initial frequency =(f+if)/(32/640)
uint8_t OSCI =1;
//uint8_t lockFlag =0;
void SNTVtuner(uint16_t RF,uint8_t OSCI)
uint16_t fpd =0;
Wire.beginTransmission(0x61);
switch (OSCI)
case 1 : //Setting for OSCIillator #1 VHF-LO
fpd = RF ;
Wire.write(fpd >> 8); //DB1
Wire.write(fpd & 0xFF ); //DB2
Wire.write(0xC8); //CB
Wire.write(0x01); //BB
case 2://Setting for OSCIillator #2 VHF-HI
fpd = RF ;
Wire.write(fpd & 0xFF); //DB2
Wire.write(0x02); //BB
case 3://Setting for OSCIillator #3 UHF
fpd = RF ;
Wire.write(fpd & 0x0FF); //DB2
Wire.write(0x08); //BB
Wire.endTransmission();
delay(10);
//Wire.requestFrom(0x61,1); //in-lock flag (FL = 1 when the loop is phase-locked)
//while (Wire.available())
//lockFlag = Wire.read();
Wire.begin();
lcd.begin(16,2);
lcd.backlight();
pinMode(clk,INPUT_PULLUP);
pinMode(dta,INPUT_PULLUP);
PreviousClock = digitalRead(clk);
SNTVtuner(RF,OSCI);
lcd.setCursor(0,0);
lcd.print("RF:");
lcd.setCursor(3,0);
lcd.print(RF*3.2/64-37); //DB1+DB2x32/640-IF
lcd.setCursor(0,1);
lcd.print("OSCI:");
lcd.setCursor(5,1);
lcd.print(OSCI);
lcd.setCursor(10,1);
//lcd.print("LF:");
//lcd.setCursor(13,1);
//lcd.print(lockFlag);
CurrentClock = digitalRead(clk);
if(CurrentClock != PreviousClock){
if(CurrentClock != digitalRead(dta)){
RF--;
SNTVtuner(RF,OSCI);
RF++;
SNTVtuner(RF,OSCI);
lcd.setCursor(0,0);
lcd.print("RF:");
lcd.setCursor(3,0);
lcd.setCursor(0,1);
lcd.print("OSCI:");
lcd.setCursor(5,1);
lcd.print(OSCI);
//lcd.setCursor(8,1);
//lcd.print("LF");
//lcd.setCursor(11,1);
PreviousClock = CurrentClock;
It's set for an initial frequency of 107.5Mhz. you can change that at RF =2890, according to the formula in the comment. To change the intermediate frequency is in the two lines lcd.print(RF*3.2/64-37), just replace 37 with whatever your IF is.
Great! You helped my dream come true. I had once a PIC16F628 and a TSA5512 based tuner from (Mirror of Freddo's Electronics Page). It got damaged accidentally, it's only the HEX data. Now Arduino open source makes it much better to customize. Lots of thanks and best wishes for all Arduino Contributors.
Here I added some luxuries leared from here and there like the RSSI bar in the display. You can get a TA2111 (CD2111) radio or any cheap one with a Stereo led and RSSI led indication and inject the signal via resistor to A0. etc, (For experienced tinkerers and hobbyists not to damage the Arduino)
//updated 25.02.24 Tested with a TA2003 based FM radio Change coils at pins 13 and 15
//Get a good antenna
//"You can dispense with SAW Filters
//It's set for an initial frequency of 107.5MHz.
//To change the intermediate frequency is in the two lines lcd.print(RF*3.2/64-37),
//you can change that at RF =2890, according to the formula in the comment.
//just replace 37 with whatever your IF is."
#include <Wire.h>
uint16_t RF =2890;//3604
uint8_t OSCI =1;
uint16_t fpd =0;
switch (OSCI)
fpd = (RF + 107) ;
Wire.write(0xC0); //CB
fpd = (RF + 107) ;
fpd = (RF + 107) ;
//delay(10);
int RSSI_IN = analogRead(A0);
byte ZeroChar[8] =
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111
byte FirstChar[8] =
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111
byte SecondChar[8] =
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111
byte ThirdChar[8] =
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111,
  B11111
byte FourthChar[8] =
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte FifthChar[8] =
  B00000,
  B00000,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte SixthChar[8] =
  B00000,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte SeventhChar[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
Wire.begin();
lcd.begin(16,2);
lcd.backlight();
SNTVtuner(RF,OSCI);
lcd.setCursor(0,0);
lcd.print("RF:          MHz");
lcd.setCursor(3,0);
lcd.print(RF*3.2/64-37);//DB1+DB2x32/640-IF
lcd.createChar(0, ZeroChar);
lcd.createChar(1, FirstChar);
lcd.createChar(2, SecondChar);
lcd.createChar(3, ThirdChar);
lcd.createChar(4, FourthChar);
lcd.createChar(5, FifthChar);
lcd.createChar(6, SixthChar);
lcd.createChar(7, SeventhChar);
delay(200);
Volume();
RF--;
SNTVtuner(RF,OSCI);
RF++;
SNTVtuner(RF,OSCI);
lcd.setCursor(0,0);
lcd.print("RF:");
lcd.setCursor(3,0);
void Volume()
        int RSS_IN = analogRead(0);
        RSS_IN = map(RSS_IN, 0, 1023, 0, 8);
        lcd.setCursor(0,1);
        if(RSS_IN==0)
        lcd.setCursor(0,1);
        lcd.print("RSS:");
        lcd.print("-");
        lcd.print(" ");
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.print(" ");
        lcd.print("+");
        if(RSS_IN==1){
        lcd.setCursor(0,1);
        lcd.print("RSS:");
        lcd.print("-");
        lcd.print(" ");
        lcd.write((byte)0);
        lcd.write((byte)1);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.print(" ");
        lcd.print("+");
        if(RSS_IN==2){
        lcd.setCursor(0,3);
        lcd.print("RSS:");
        lcd.print("-");
        lcd.print(" ");
        lcd.write((byte)0);
        lcd.write((byte)1);
        lcd.write((byte)2);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.print(" ");
        lcd.print("+");
        if(RSS_IN==3){
        lcd.setCursor(0,3);
        lcd.print("RSS:");
        lcd.print("-");
        lcd.print(" ");
        lcd.write((byte)0);
        lcd.write((byte)1);
        lcd.write((byte)2);
        lcd.write((byte)3);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.print(" ");
        lcd.print("+");
        if(RSS_IN==4){
        lcd.setCursor(0,3);
        lcd.print("RSS:");
        lcd.print("-");
        lcd.print(" ");
        lcd.write((byte)0);
        lcd.write((byte)1);
        lcd.write((byte)2);
        lcd.write((byte)3);
        lcd.write((byte)4);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.print(" ");
        lcd.print("+");
        if(RSS_IN==5){
        lcd.setCursor(0,3);
        lcd.print("RSS:");
        lcd.print("-");
        lcd.print(" ");
        lcd.write((byte)0);
        lcd.write((byte)1);
        lcd.write((byte)2);
        lcd.write((byte)3);
        lcd.write((byte)4);
        lcd.write((byte)5);
        lcd.write((byte)0);
        lcd.write((byte)0);
        lcd.print(" ");
        lcd.print("+");
         if(RSS_IN==6){
        lcd.setCursor(0,3);
        lcd.print("RSS:");
        lcd.print("-");
        lcd.print(" ");
        lcd.write((byte)0);
        lcd.write((byte)1);
        lcd.write((byte)2);
        lcd.write((byte)3);
        lcd.write((byte)4);
        lcd.write((byte)5);
        lcd.write((byte)6);
        lcd.write((byte)0);
        lcd.print(" ");
        lcd.print("+");
         if(RSS_IN==7){
        lcd.setCursor(0,3);
        lcd.print("RSS:");
        lcd.print("-");
        lcd.print(" ");
        lcd.write((byte)0);
        lcd.write((byte)1);
        lcd.write((byte)2);
        lcd.write((byte)3);
        lcd.write((byte)4);
        lcd.write((byte)5);
        lcd.write((byte)6);
        lcd.write((byte)7);
        lcd.print(" ");
        lcd.print("+");
