Hi guys, I am new the world of arduino, really electronics in general, and I am having trouble hooking up a RN41XV to the Uno. I attempted to connect them once and i fried the Bluetooth chip and as I am new I’m going to chalk it up to me not understanding the datasheet, can anyone explain how the two are supposed to be wired? I can’t seem to find an actual image depicting the two in a schematic. All I am doing is trying to hook up the two to have basic communication in and out over bluetooth
Do you have something cool like this : https://www.sparkfun.com/products/11600
Please give a link to your product.
Peter_n:
Do you have something cool like this : RN41-XV Bluetooth Module - Chip Antenna - WRL-11600 - SparkFun Electronics
That is exactly the one
The Uno is a 5V board, and that RN41XV is a 3.3V module. Do you have something in between ?
Peter_n:
I do not, the uno has a 3.3v pin is it not 3.3v? If not that explains why i blew the first one.
I attached an image of the arduino for reference, the 3.3 is right next to reset
I was assuming that you need to convert all the signals.
With something like these:
This project uses an SD shield that suitable for XBee: http://ipv6poclab.org/2014/01/13/motion-sensor-via-xbee-connected-arduinos/
However, I think something very simple like this, might just be enough:
I don't know what will happen if you connect a 5V SPI signal to the XBee :~
Peter_n:
http://www.adafruit.com/products/126?&main_page=product_info&cPath=29&products_id=126
SparkFun XBee Explorer Regulated - WRL-11373 - SparkFun Electronics
This project uses an SD shield that suitable for XBee: http://ipv6poclab.org/2014/01/13/motion-sensor-via-xbee-connected-arduinos/However, I think something very simple like this, might just be enough:
ForceTronics: Getting Started with the RN42 Bluetooth ModuleI don't know what will happen if you connect a 5V SPI signal to the XBee :~
That's actually exactly what i was looking for (I'm using an xbee breakout board to connect to the bread board), I'll try it once I'm home for the day!
