How to properly count time - Uno R4 Wifi
`#include <Wire.h>
// Set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x27, 16, 2);
#define BTN_RST 2
#define GATE 4
#define PP 7
#define LP 8
#define P_LED 12
#define L_LED 13
int mm = 0, ss = 0, ms = 0;
bool runTimer = false; // 1 = run, 0 = wait
int lmm, lss, lms;
int pmm, pss, pms;
  // iputs
  pinMode(GATE, INPUT);
  pinMode(PP, INPUT_PULLUP);
  pinMode(LP, INPUT_PULLUP);
  pinMode(BTN_RST, INPUT);
  // outputs
  pinMode(P_LED, OUTPUT);
  pinMode(L_LED, OUTPUT);
	// initialize the LCD
	lcd.begin();
	// Turn on the blacklight and print a message.
	lcd.backlight();
	lcd.setCursor(4,0);
  lcd.print("GOOD LUCK");
  delay(5000);
  lcd.clear();
  if(digitalRead(GATE) == 1)
  lcd.setCursor(6,0);
  lcd.print("Ready");
    lcd.clear();
    stopwatch();
void stopwatch()
  runTimer = true;
  while(runTimer == true)
    ms++;
    if(ms>27)
      ms = 0;
      ss++;
    if(ss>59)
      ss = 0;
      mm++;
    if(mm>59)
      runTimer = false;
      digitalWrite(P_LED, LOW);
      digitalWrite(L_LED, LOW);
      lcd.clear();
    if(digitalRead(LP) == LOW)
      digitalWrite(L_LED, HIGH);
    if(digitalRead(LP) == HIGH)
      lmm = mm;
      lss = ss;
      lms = ms;
    if(digitalRead(PP) == LOW)
      digitalWrite(P_LED, HIGH);
    if(digitalRead(PP) == HIGH)
      pmm = mm;
      pss = ss;
      pms = ms;
    if(digitalRead(BTN_RST) == HIGH)
      runTimer = false;
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print("P ");
      lcd.print((pmm/10)%10);
      lcd.print(pmm%10);
      lcd.print(":");
      lcd.print((pss/10)%10);
      lcd.print(pss%10);
      lcd.print(":");
      lcd.print((pms/100)%10);
      lcd.print((pms/10)%10);
      lcd.print(pms%10);
      lcd.setCursor(0,1);
      lcd.print("L ");
      lcd.print((lmm/10)%10);
      lcd.print(lmm%10);
      lcd.print(":");
      lcd.print((lss/10)%10);
      lcd.print(lss%10);
      lcd.print(":");
      lcd.print((lms/100)%10);
      lcd.print((lms/10)%10);
      lcd.print(lms%10);
The code will run one stopwatch and saving 2 diferent times. My problem is with counting milliseconds. (I know that 1s != 27ms, it was used only for approxymately value) How can i create stopwatch without using Timer_Compa_vect, please? Ms are very important in may project.
(pms,... stands for right time; lms,... stands for left time)
how can i implement it, please?
look this over
  0:03.863
  0:03.875
  0:03.888
  0:03.900
  0:03.913
  0:03.926
  0:03.938
  0:03.950
  0:03.962
  0:03.975
  0:03.988
  0:04.000
void loop (void)
    unsigned long msec = millis ();
    int secs  = msec / 1000;
    int mins  = secs / 60;
        secs %= 60;
        msec %= 1000;
    char s [20];
    sprintf (s, " %2d:%02d.%03lu", mins, secs, msec);
    Serial.println (s);
void
setup (void)
    Serial.begin (9600);
