How to properly initialize structs?
I am not used to C++, only plain C...
I have a struct definition like this inside the espconfig.h file:
typedef struct __attribute__((__packed__))
  unsigned int checksum;
  char ssid[32];
  char passwd[32];
  byte addr[4];
  long baud;
  unsigned int tcpport;
  byte mode; //WIFI_AP, WIFI_STA, WIFI_AP_STA or WIFI_OFF
  byte reserved[23]; //For future expansion
} ESPConfiguration;  // Size: 100 bytes
It is meant to be saved in EEPROM to hold my configuration items.
In the LoadConfig() function located in a regular C++ espconfig.cpp file I have this:
int LoadConfig(ESPConfiguration *Conf)
// Read configuration data from EEPROM, return 0 if OK
  ESPConfiguration Cnf = {0};  //Temp struct
  //Load struct from EEPROM
  EEPROM.get(0, Cnf);
  //Calculate checksum:
  chk = Cnf.checksum;  //Save stored checksum
  Cnf.checksum = 0;    //Clear checksum before calculation
  if (CheckSum(&Cnf, sizeof(Cnf)) == chk){ //Validated checksum
    Cnf.checksum = chk;//Restore checksum
    *Conf = Cnf;       //Return struct
    return 0;
    return -1;   //Return without changing data
When I verify this I get a warning about the initialization of the local struct variable:
..\espconfig.cpp:19:28: warning: missing initializer for member 'ESPConfiguration::ssid' [-Wmissing-field-initializers]
This way to initialize (zero out) a struct was taken from an example on the web, but apparently it is not really correct. So I wonder how does one initialize the struct correctly?
The correct form is:
ESPConfiguration Cnf = {};  //Temp struct
See: zero initialization - cppreference
Or memset(struct XXXX, 0, sizeof struct XXXX);
giova014:
I tried that but it gave the same error message...
..\espconfig.cpp:20:27: warning: missing initializer for member 'ESPConfiguration::checksum' [-Wmissing-field-initializers]
I do not want to list every member since there are arrays there and when I do not list all items in the array it still complains like this.
boylesg:
Did not work:
..\espconfig.cpp:22:10: error: expected primary-expression before 'struct'
   memset(struct Cnf, 0, sizeof struct Cnf);
Taking away the initialization completely removed the error/warning messages, but what will then be in the struct data?
BosseB:
Why do you care? The first thing you do is overwrite it with data from EEPROM.
Yes in this case you are completely correct!
Why bother, indeed.
OTOH I am on a learning trip while at the same time creating the ESP8266 application we need.
Memset definately works if used properly:
typedef struct MYSTRUCT {
  int a, b, c;
MYSTRUCT ms;
memset(&ms, 0, sizeof(MYSTRUCT));
