How to Properly Power My Project with Three Motors
Hi everyone,
I’m a beginner working on a project where I need to control three underwater DC motors (12-16V, 5A, 5000 RPM). I based my circuit design on the motor control setup from this project:
[Arduino Underwater ROV - Science Buddies]
My Setup:
3 DC motors (12-16V, 5A, 5000 RPM)
L293D motor driver to control direction
Arduino Uno
LEDs for direction indication (blue = forward, yellow = reverse)
9V battery (temporary, just for demonstration purposes, not for actual use)
My Question:
What’s the best way to power this setup?
I know that the 9V battery is not sufficient, but I’m unsure what power source I should use to properly run the motors. Any recommendations would be greatly appreciated!
My Code:
const int tiraPin[3] = {7, 9, 11};
const int spingiPin[3] = {8, 10, 12};
  Serial.begin(9600); // Inizializza la comunicazione seriale
  for (int i=0; i<3; i++) {
    pinMode(tiraPin[i], OUTPUT);
    pinMode(spingiPin[i], OUTPUT);
  pinMode(13, OUTPUT);
    digitalWrite(tiraPin[i], HIGH);
    digitalWrite(spingiPin[i], LOW);
    digitalWrite(tiraPin[i], LOW);
    digitalWrite(spingiPin[i], HIGH);
You need a battery pack unless you can use a power supply connected to grid power or a generator or PV panel.
I don't know how long your project needs to run so I can't say how many of what kind of batteries you need. For a short demo you might get away with 2 AA's and a DC-DC Boost Converter (95+% efficient, for small current they're cheap) if you need more than 3V. For a real short demo you might get away with a coin cell of sufficient V.
Your motors are rated 5A each and you have 3 of them.
Maybe some kind of lead-acid or lithium-ion 12V battery, but check that it is rated for 15A + 20% for safety, and choose the capacity depending on how long you want the project to run between re-charges. Even if on average your motors draw only 2.5A each, you will need a battery with 7.5Ah capacity if you want them to run 1 hour between charges.
Warning 1: a breadboard can carry currents of up to 1A absolute maximum. You need to route the motor current away from your breadboards using suitable gauge wires.
Warning 2: L293D can supply up to 600mA current to a motor, so you need to choose motor drivers with many times higher max current.
You will need a BIG battery pack for the underwater motors. Since the battery will be above the water, the wires connecting the battery to the motors will be a loss unless they are very large gauge. You mention 5A, is that for each motor or total? If the total is one kind of battery, if each is a much BIGGER battery.
The UNO can use a small battery pack, maybe one of those USB power packs but the UNO can NOT supply power to anything else in your setup.
As @PaulRB said, that driver is completely useless for those motors. Check the Pololu website for information on motor drivers.
Do you realise that you are basing your project on one using toy motors ('thrusters'), probably using mere milliamps?
"- Underwater Thruster: Powerful and unique underwater for your toy."
So if you really are planning for three motors using up to 5A each...
Place them in the trash, they cannot begn to drive your motor(s). Take a look at the BTS7960 module it has a rating greater then the motors so it should work fine. I have had great luck with them. This link may help: https://www.instructables.com/Motor-Driver-BTS7960-43A/
