I am building a datalogger that will POST data to a website and I would like to design it to run for years.
The way I have it set up is that it resets the W5200 when it fires up. Then resets the connection with this (resetPin is the reset of the the W5200 module):
void resetCon() {
wdt_reset();
digitalWrite(resetPin, LOW);
delay(2000);
digitalWrite(resetPin, HIGH);
wdt_reset();
#if defined(WIZ550io_WITH_MACADDRESS)
if (Ethernet.begin() == 0) {
#else
if (Ethernet.begin(mac) == 0) {
#endif
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
// try to congifure using IP address instead of DHCP:
wdt_reset();
Ethernet.begin(ip);
#else
Ethernet.begin(mac, ip);
#endif
This works fine at first. The problem comes when a connection is not made, I call resetCon() again just to make sure that this is not the issue. When I do this, my RAM drops by over 100 each time.
How can I reset the connection without eating up my RAM?
I wrote the resetCon() function to incorporate parts of the sketch. That is not part of any library.
My goal for this sketch is to test Arduino as a remote datalogger that could potentially be installed in thousands of locations and operate for years without human interaction. So if something goes wrong, I want the unit to completely reset itself.
The reason I have the reset in the connection is to act as a 'catch all'. If it loses connection for any reason, it will just reset. That way, even if some strange condition arises, it will eventually correct itself.
For now, I just have it set to monitor the free memory, and if it drops below 250, it times out the watchdog and does a full system reset. Not the most elegant, but at least it should work.
Are you saying that I can drop the reset and it should still function the same?
