I’m very new to programming things, so I’m probably making a simple mistake. I only want a servo to execute the “sweep” example program only when I’m getting an input on pin 2, but it’s always moving no matter what. Here’s my code, how can I fix this?
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
int tripped = 0;
const int tripwire = 2;
myservo.attach(9); // attaches the servo on pin 9 to the servo object
pinMode(tripwire, INPUT);
tripped = digitalRead(tripwire);
Serial.print(tripped);
if (tripped == HIGH) {
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable ‘pos’
delay(15); // waits 15ms for the servo to reach the position
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
delay(15);
int tripped = 0;
Serial.println(tripped);
delay(15);
delay(15);
Use CTRL T to format your code.
Attach your ‘complete’ sketch between code tags, use the </> icon in the posting menu. [code]Paste your sketch here[/code]
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15);
You may want to use switch state change detection instead of switch level.
Did you want the servo to sweep one way while the switch is being pressed then the other way when released ?
If you have it wired up to ground, when it is not pressed, it is floating and you need to declare the pin as INTPUT_PULLUP so that it will read HIGH when not pressed and LOW when pressed.
