To save power, I put the esp in light sleep mode at regular intervals with a timer and touch wake up. During this time, the mqtt messages don't get published because Wi-Fi gets turned off.
I use bool publish(const String &topic, const String &payload, bool retained, int qos);
with retained=false and QoS=1
Should that ensure that older pending messages get cached and then published once the device comes back online? That does not happen.
I'm interested to know if this is how the protocol is supposed to work or whether this is a library limitation and I'm supposed to implement offline message queuing myself.
void WiFiStationDisconnected(WiFiEvent_t event, WiFiEventInfo_t info)
connectToWiFi();
esp_sleep_enable_timer_wakeup(5000* 1000);
esp_sleep_enable_touchpad_wakeup();
WiFi.onEvent(WiFiStationDisconnected, WiFiEvent_t::ARDUINO_EVENT_WIFI_STA_DISCONNECTED);
mqttClient.loop();
if (millis() - pollAllSensorsTime > 5000)
connectToMqtt();
pollSensorsAndPublish(); // All of them are environmental I2C sensors
printToLcd();
pollAllSensorsTime = millis();
esp_light_sleep_start();
If loop() stops during light sleep then it is not collecting data during that time. The LCD does update every 5 seconds, so it is reading the sensors. However, I receive the mqtt messages only once a while, probably because Wifi may not have reconnected in time right after a wakeup.
I guess this does not do what I want to do. I may need to use modem sleep as well, to do something like:
wake up in modem sleep
poll sensors
light sleep for 5 seconds, go to 1
disable modem sleep once every 60 seconds, publish mqtt data
enable modem sleep again
In any case I need a way to queue the offline messages, which was my original question and I thought that using qos=1 would do it.
You might be able to write a program for the ULP to read the sensors when the main processor is sleeping but, to me, your lack of understanding of what the ESP32 is doing casts doubt.
