Hello there,
The model of the board is S2-1040U-Z1K0B
I've searched the datasheet but I didn't understand a lot.
Also, I don't think there is a DTR pin on the board. (as if I know what that is...)
Any help will be appreciated!
Thanks in advance!
Hello there,
Thanks in advance!
i was able to put my sim800L to sleep with
at+cslk=2
the continuos current went from 13mA down to 1mA (LED not stripped off)
incoming SMS/call wakes the device back up or sending dummy AT command then wait
AT
delay(5); //wait, well you don't need this if you are using the DTR pin
UART will be up and running again
for more you can check HW design datasheet for sim900A,
KASSIMSAMJI:
at+cslk=2for more you can check HW design datasheet for sim900A,
I think the equivalent for the SIM900A is AT+CFUN=0
joker65:
you are not going to receive any SMS or call with AT+CFUN=0
that's flight mode
