How to read 0volts to 14Volts in analog input arduino uno?It's possible?
I'm trying to develop a speedometer for my car, using the vss signal (Velocity speed sensor), with CI LM2907/2917 (Frequency to voltage converter), but starting from 83km / h 5.03 Volts. how I use the analog input of the Arduino to read voltage above 5volts? When you reach 220Km/h the voltage is 13.33 volts. Can someone help me?
You use a potential divider ( two resistors ) to cut down the voltage so that with maximum voltage you only get 5V at the arduino input.
–[VIN -----[ 100k resistor]— --------------------------------------> >-----(Arduino analog input)
[47 k ohm]
V (GND)
Resistors too large.
Effective input impedance of the Arduino input in analog mode is of the order of 10k - and probably not constant because it depends on how rapidly you sample.
First approximation (probably sufficient), use 10k and 4k7. If you want more accuracy, buffer it with an op-amp.
That's OP AMP VOLTAGE FOLLOWER for you OP AMP challenged folks ..... XD
Thank you, raschemmel was what I was thinking of doing. I think it will work that way. :grin:
thank you Grumpy Mike for help.
You should be able to use a pot as an adjustable voltage divider to set the input voltage to the arduino as desired .
10k to 20 k would probably be the best range.
Just get an inexpensive hand full on ebay. . http://www.ebay.com/sch/i.html?_odkw=potentiometer+10k&LH_BIN=1&_sop=15&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xpotentiometer+10k+10pcs&_nkw=potentiometer+10k+10pcs&_sacat=0
