i want to configure some sketch variables using a html form.
I bought the Ethernet shield and now i am going to make a small formular where i can set the ip number for exmple.
I am going to do this using four text fields.
I do not know how to read the field values!
To switch some leds I can make:
if(string.contains("LED1=on")){
// turn the led on
if(string.contains("LED1=off")){
//turn the led off
With two values 'on' and 'off' this way is ok.
But now one field has more then only two values (in my exemple 0 - 255).
Do you have any idea how to solve my problem?
Thanx.
It’s not complete but it gives you a place to start. You also need: #include <WString.h> which you have to download.
void loop(){
Client client = server.available();
if (client)
while (client.connected())
if (client.available())
char c = client.read();
if (readString.length() < 100)
readString.append(c);
if (c == '\n')
//code for pin 8
if(readString.contains("toggle8"))
int state = toggle(8);
if(debug){ Serial.println("toggle8 received "); Serial.println(state); }
client.print("done8");
client.print(state);
Below is some server code that collects a “get” request (query_string) from a web brouser, does some string operations on the obtained string, and sends a reply back to the browser. You may have to look into the Ethernet.h code to see if it can obtain all the info sent by the browser.
//zoomkat 5-24-10
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
Server server(84); //server port
String readString = String(100); //string for fetching data from address
String teststring = String(100);
String finalstring = String(100);
String flag = String(2);
int ind1 = 0;
int ind2 = 0;
int pos = 0;
void setup(){
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
//enable serial data print
Serial.begin(9600); }
void loop(){
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
//if HTTP request has ended
if (c == '\n') {
//Serial.println(readString);
//readString looks like "GET /?-0p1555-1p500t1000 HTTP/1.1"
if(readString.contains("-")) { //test for servo control sring
readString.replace('-', '#');
pos = readString.length(); //capture string length
//find start of servo command string (#)
ind1 = readString.indexOf('#');
//capture front part of command string
teststring = readString.substring(ind1, pos);
//locate the end of the command string
ind2 = teststring.indexOf(' ');
//capturing the servo command string from readString
finalstring = readString.substring(ind1, ind2+ind1);
//print "finalstring" to com port;
Serial.println(finalstring); //print string with CR
//GET /?Slidervalue0=1800&Submit=Sub+0 HTTP/1.1
if(readString.contains("Slidervalue")) {
ind1 = readString.indexOf('u');
ind2 = readString.indexOf('&');
finalstring = readString.substring(ind1+1, ind2);
finalstring.replace('e', '#');
finalstring.replace('=', 'p');
//now output HTML data header
client.println("HTTP/1.1 204 Zoomkat");
client.println();
client.println();
delay(1);
//stopping client
client.stop();
//clearing string for next read
readString="";
teststring="";
finalstring="";
Does anyone know how to get this to work with Arduino21? I'm having difficulty getting past the HTML headers without being able to use the .append function that you could use with older versions of Arduino.
I'm also having problems using:
c == '\n'
I don't seem to be able to detect this. within the string I'm reading
