How to read a pot state change.
I am using a mega to run the code below, which runs as i want. I am now stuck and was hoping somebody may be able to help or maybe has done a similar thing. What i want to be able to do is after a certain amount of time, say 60 seconds, is to break out of the loop (to avoid the motors running on forever and burning out) regardless of which position the pot is in, and to be in a state like in case 1 with everything off, but if the pot is then moved to a different position then the loop will start again. I am really stuck on this and have no idea where to even begin!!
Any help would be very much appreciated.
Thanks.
const int sensorMin = 0;
const int sensorMax = 1023;
int pwm_a = 3; //PWM control for motor outputs 1 and 2
int pwm_b = 11; //PWM control for motor outputs 3 and 4
int dir_a = 12; //dir control for motor outputs 1 and 2
int dir_b = 13; //dir control for motor outputs 3 and 4
int led1 = 35;      //led1
int led2 = 39;      //led2
int led3 = 43;      //led3
  pinMode(pwm_a, OUTPUT);
  pinMode(pwm_b, OUTPUT);
  pinMode(dir_a, OUTPUT);
  pinMode(dir_b, OUTPUT);
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
void loop(){
  int sensorReading = analogRead(A0);
  int range = map(sensorReading, sensorMin, sensorMax, 1, 3);
  switch (range) {
   case 1:{
      digitalWrite(dir_a, LOW);
      digitalWrite(dir_b, LOW);
      analogWrite(pwm_a, 0);
      analogWrite(pwm_b, 0);
      digitalWrite(led1, LOW);
      digitalWrite(led2, LOW);
      digitalWrite(led3, LOW);
   case 2:{
      analogWrite(pwm_a, 100);
      analogWrite(pwm_b, 100);
      digitalWrite(led1, HIGH);
      delay(50);
      digitalWrite(led2, HIGH);
      delay(50);
      digitalWrite(led3, HIGH);
      delay(50);
      delay(50);
      case 3:{
      delay(50);
      delay(100);
      delay(100);
      delay(100);
Either in loop create static variables to hold the time and previous pot state or create them globally.
after working out range using map compare it to previous range and if different then execute the switch section and copy the current state the previous state. also include in the switch section code to get the current time (millis()) in the main loop include code that checks current millis() against value acquired in the switch statement and if the difference is > timeout period then stop motor.
Thanks Riva.
Do you know of any example code as I am relatively new to the arduino ide and have never done anything like this before.
void loop(){
At the moment the code acts on the sensorReading in every iteration of loop() [probaply hundreds of times per second] even if the value has not changed.
You could add code so it only goes through the rest of the stuff if the value changes
void loop(){
  if (sensorReading != oldSensorReading) {
      // all the existing stuff
  oldSensorReading = sensorReading;
That should give you a starting point for determining when to restart the motor.
Then you can add another few lines to see if it is time to switch off the motor
void loop(){
      motorOnMillis = millis();
  else {
    if (millis() - motorOnMillis > runTimeMillis) {
       // motorOff
There is a small complication - because you are using a Pot successive readings by the ADC maynot give identical values even if the pot is not moved. So rather than checking for equailty you need to allow a little slack - perhaps ignore a difference of less than 5.
Something like if (abs(prevSensoReading - sensorReading) <= 5)
…R
makerpaul: Do you know of any example code as I am relatively new to the arduino ide and have never done anything like this before.
Something like below. The code compiled but is untested and needs motor off code inserting where comment specifies.
const unsigned long timoutTime = 60000UL;   // Timout (60 seconds)
unsigned long prevTime;
int prevRange = -1;   // -1 to force update on firsts pass through loop
void loop(){
  if (range != prevRange){
    prevRange = range;
    prevTime = millis();
    switch (range) {
      case 1:{
      case 2:{
        delay(50);
        delay(50);
        delay(50);
        delay(50);
      case 3:{
        delay(50);
        delay(100);
        delay(100);
        delay(100);
  if ((millis() - prevTime) > timoutTime){
    // Stop motor code here
Thanks so much guys for taking the time to help me with this, it is very much appreciated, I now have it working exactly how I wanted!!
Further to what I said earlier, I had only tried this with my motor connected to my board, the motor with the timer works perfectly, the problem I have is that in case 2 and case 3 the leds need to flash on and off repeatedly, with the code above it only runs through the case once so the leds flash on then off once and the loop doesn't repeat. I have tried to adjust the code but am having no luck. Any help on this would be really great. Thanks
makerpaul: with the code above it only runs through the case once so the leds flash on then off once and the loop doesn't repeat. I have tried to adjust the code but am having no luck.
Show us the latest version of the code. Otherwise we are just aiming in the dark.
...R
Sorry, meant to post the code I am having difficulties with. The problem is that the leds are supposed to flash on and off continuously until it timeouts but it only goes through the loop once. Any help would be really appreciated. Here is the code.
const unsigned long timoutTime = 6000UL;   // Timout (60 seconds)
void loop(){
    prevRange = range;
    switch (range) {
    case 1:
    case 2:
        delay(50);
        delay(50);
        delay(50);
    case 3:
        analogWrite(pwm_a, 250);
        analogWrite(pwm_b, 250);
        delay(100);
        delay(100);
        delay(100);
Try this...
void loop(){
    prevRange = range;
    range = 1;
  switch (range) {
    case 1:
    case 2:
      delay(50);
      delay(50);
      delay(50);
    case 3:
      delay(100);
      delay(100);
      delay(100);
Thanks for all your help Riva. I had been struggling with this for an age, and I have learnt a lot from your help. Very much appreciated.
