How to read and display 24 bit two's compliment in decimal form
I am trying to read the data from an ADS1231, which is stored in 24 bit two's compliment. In my code I am shifting in all three bytes, but what would be the correct type of variable to store and then read the data from. Also, how could I convert the two's compliment to a voltage. Thanks.
brett_bender: I am trying to read the data from an ADS1231, which is stored in 24 bit two's compliment. In my code I am shifting in all three bytes, but what would be the correct type of variable to store and then read the data from. Also, how could I convert the two's compliment to a voltage. Thanks.
A long variable type should be the type you should fill your bytes into.
Lefty
Use a long (int32_t) and then extend the sign bit.
majenko:
Could you explain? Should I convert the two’s compliment value into a normal binary value?
What should I add to this to extend the sign bit?
nt32_t value = 0;
    while (digitalRead(data) == LOW){
    value = shiftIn(data, sclk, MSBFIRST);
    value <<= 8;
    value |= shiftIn(data, sclk, MSBFIRST);
    value <<= 8;
A two’s complement is a binary value.
// Shift in the values
value <<= 8;
value <<= 8;
// Sign extend - set bits 24 to 31 the same as bit 23
if (value & 0x0800) {
  value |= 0xF000;
