Hai all.
i new in arduino and don't know too much in programming
i have (.csv) file. the (.csv) file format like this
row1 | clock1| clock2
row2 | clock1| clock2
how i can seperates row and column
the code just reading a file.
while (file.available()) {
fileRead = file.read();
Serial.print(fileRead);
//Serial.print(hari);
anyone can help me
Thanks
gcjr
April 11, 2022, 7:36pm
2
after reading each line, consider using strtok()
thank for you respon
now my code like this, but in Serial monitor not show any value;
char value = strtok(fileRead, ",");
while(value != NULL){
Serial.print(value);
value = strtok(NULL, ",");
file.close();
can you write example? please
gcjr
April 11, 2022, 8:25pm
4
i typically do something like
char s [80];
#define MaxTok 10
char *toks [MaxTok];
int vals [MaxTok];
int
tokenize (
char *s,
const char *sep )
unsigned n = 0;
toks [n] = strtok (s, sep);
vals [n] = atoi (toks [n]);
for (n = 1; (toks [n] = strtok (NULL, sep)); n++)
return n;
void dispToks (
char * toks [])
char s [40];
for (unsigned n = 0; toks [n]; n++) {
sprintf (s, " %6d %s", vals [n], toks [n]);
Serial.println (s);
void loop ()
if (Serial.available ()) {
int n = Serial. readBytesUntil ('\n', s, sizeof(s));
s [n] = 0; // terminate string
tokenize (s, ",");
dispToks (toks);
void setup ()
Serial.begin (9600);
thank you very much for your advice. i want to try to write your code. I hope this can solve my problem
system
Closed
October 8, 2022, 8:33pm
6
