How to read data from my projector's serial port?
Hi. I am trying to make a device that can control my projector from its serial port. I am using a max232 device to connect my Arduino to the projector. I am able to send commands to turn it on and off and such but I want to be able to read data from it. So I wrote this piece of code that asks the projector what its power state is. This works and I am able to get a response from the projector and output it to the serial monitor. Now, I want to be able to set a boolean based on the data I receive. How can I do that?
Here is a link to the manual for controlling the projector via its serial port (I am looking at page 8 for the list of commands) : https://benqesupport.blob.core.windows.net/esupport/Projector/Control%20Protocols/HT3550/RS232%20Control%20Guide_0_Windows10_Windows7_Windows8.pdf
here is the code I wrote:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
String incomingData;
mySerial.begin(9600);
mySerial.write("*pow=?#");
mySerial.write('\r');
if (mySerial.available() > 0) {
incomingData = mySerial.readString();
Serial.println(incomingData);
delay(5000);
This is the output I receive from the serial monitor:
*pow=?#
*POW=OFF#
or
*pow=?#
*POW=ON#
I need to ignore the first part as it comes in corrupted sometimes.
Thanks in advance.
Here is the reference for the String class..
Here is one way to look for substrings using the indexOf() function.
   if (incomingData.indexOf("ON") >= 0) // is "0N" in the inout
      Serial.println("projector is on");
   else if (incomingData.indexOf("OFF") >= 0)
      Serial.println("projector is off");
   delay(5000);
@groundFungus reply is spot on.
Here is a slightly different sketch. It includes testing the *pow= start of the response. What sort of corruption are you getting.? Do you still get it with this sketch?
// for testing uncomment this to test from Serial input
// #define mySerial Serial
void clearMySerialInput() {
  mySerial.setTimeout(100);
  mySerial.setTimeout(5);
  mySerial.setTimeout(5); // at 9600 get about 1char/1mS so when reading user input from Arduino IDE monitor can set this short timeout
  for (int i = 10; i > 0; i--) {
    Serial.print(' '); Serial.print(i);
  Serial.println(F("mySerial Started"));
  clearMySerialInput(); // flush any pending input
bool haveSentCmd = false;
void processInput() {
  if (Serial.available()) { // skip readString timeout if nothing to read
    String input = Serial.readString();
    input.trim(); // strip off any leading/trailing space and \r \n
    if (input.length() > 0) {  // got some input handle it
      Serial.print(F(" got a some input '")); Serial.print(input); Serial.println("'");
      // parse input here and set globals with results
      if (!haveSentCmd) {
        // just data printed above
        // handle response
        if (input.startsWith("*pow=")) {
          if (input.indexOf("ON") >= 0) { // is "0N" in the input
            Serial.println(F("projector is on"));
          } else if (input.indexOf("OFF") >= 0) {
            Serial.println(F("projector is off"));
          Serial.println(F("unexpected response!!"));
  if (!haveSentCmd) {
    mySerial.print("*pow=?#");     mySerial.print('\r');
    haveSentCmd = true;
  processInput(); // handle the Serial in this task
  // other tasks here
This worked perfectly! Thank you so much I learned something new today
The corruption may have been due to sending while receiving on the Software Serial.
If the sketch works then fine.
Other alternatives are
i) use a Mega2560 which has extra hardware serial ports
ii) use D0/D1 for the projector connection and use the Software Serial for the debugging prints to the Console. You would need a 5V TTL to USB connector to do that, or another UNO to pass the output through
