How to read data from VB
I'm new for both software.
I want to input a number and click a button in VB, so that it gives data to Arduino.
Can someone give me any hint? or a simple example? :slight_smile:
Most Arduinos communicate with a PC over a serial connection through a USB port. Most languages have hooks for Serial interface (Python, PERL, Java, C, etc), so I'm sure VB will be able to talk to an Arduino this way. As a matter of fact, Googling "visual basic arduino serial communication" gives a whole lot of hits, including tutorial videos.
Have a look at Serial Input Basics. If you can designe your system like example 3 it will be most reliable.
...R
Hey, Lufan76, you can use something like this:
char val;         // variable to receive data from the serial port
int ledpin = 13;  // LED connected to pin 13 (on-board LED)
  pinMode(ledpin, OUTPUT);  // pin 13 (on-board LED) as OUTPUT
  Serial.begin(9600);       // start serial communication at 9600bps
  if( Serial.available() )       // if data is available to read
    val = Serial.read();         // read it and store it in 'val'
  if( val == 'H' )               // if 'H' was received
    digitalWrite(ledpin, HIGH);  // turn ON the LED
  if( val == 'L' )               // if 'H' was received
    digitalWrite(ledpin, LOW);  // turn OFF the LED
  delay(100);                    // wait 100ms for next reading
If u open Serial Monitor and type H pin 13 state will be high, type L will make it low. After that you can send characters from VB and controll it. It will be better if you use numbers.
