fat16lib, thanks to your sketch, I write a couple of functions to manage long file and directory names (read only)
I use them in my project (basically a mp3 reader). But I suppose they can be useful for other projects. For example a web server based on pages stored in a SD card.
May be you can include this functions or something equivalent in your library?
Here is the sketch to demonstrate their use
#include <SPI.h>
#include <SdFat.h>
// Control Select pin of SD card
const uint8_t SD_CS_PIN = 9;
SdFat sd;
SdBaseFile* dirFile;
// Search for the first file in a directory
// parameters:
// char * lfn : where to store the 'long name' file
// (must have a dim of at least 131 char)
// char * sdn : the directory (short name) we want to scan
// return:
// a dir_t object pointing to the founded file
dir_t dirLfnFirst( char * lfn, char * sdn )
sd.chdir( sdn );
dirFile = sd.vwd();
dirFile->rewind();
return dirLfnNext( lfn );
// Search for the next file
// parameters:
// return:
dir_t dirLfnNext( char * lfn )
uint8_t offset[] = {1, 3, 5, 7, 9, 14, 16, 18, 20, 22, 24, 28, 30};
dir_t dir;
uint8_t lfnIn = 130;
uint8_t i;
uint8_t ndir;
uint8_t sum;
uint8_t test;
bool haveLong = false;
while( dirFile->read( &dir, 32 ) == 32 )
if( DIR_IS_LONG_NAME( &dir ) )
if( ! haveLong )
if(( dir.name[0] & 0XE0 ) != 0X40 )
continue;
ndir = dir.name[0] & 0X1F;
test = dir.creationTimeTenths;
haveLong = true;
lfnIn = 130;
lfn[ lfnIn ] = 0;
else if( dir.name[0] != --ndir || test != dir.creationTimeTenths )
haveLong = false;
continue;
char *p = (char*) & dir;
if( lfnIn > 0 )
lfnIn -= 13;
for( i = 0; i < 13; i++ )
lfn[lfnIn + i] = p[offset[i]];
else if( DIR_IS_FILE_OR_SUBDIR( &dir )
&& dir.name[0] != DIR_NAME_DELETED
&& dir.name[0] != DIR_NAME_FREE
&& dir.name[0] != '.' )
if( haveLong )
for( sum = i = 0; i < 11; i++ )
sum = (((sum & 1) << 7) | ((sum & 0xfe) >> 1)) + dir.name[i];
if( sum != test || ndir != 1 )
haveLong = false;
if( haveLong )
for( i = 0; lfnIn + i <= 130 ; i++ )
lfn[i] = lfn[lfnIn + i];
return dir;
// else if( dir.reservedNT )
// return "Reserved NT";
SdFile::dirName( dir, lfn );
return dir;
if( dir.name[0] == DIR_NAME_FREE )
haveLong = false;
lfn[ 0 ] = 0;
return dir;
// Convert a 'long name' file to a 'short name' file
// parameters:
// char * sn : where to store the 'short name' file
// char * dn : the directory (short name) where is the file
// char * ln : the 'long name' file we want to convert
// size_t lln : the length of the long name file. If 0 (default),
// calculated with strlen( ln )
// return:
// true, if convertion is done
boolean l2sName( char * sn, char * dn, char * ln, size_t lln = 0 );
boolean l2sName( char * sn, char * dn, char * ln, size_t lln )
char ln0[131];
ln0[0] = 0;
dir_t dir = dirLfnFirst( ln0, dn );
if( lln == 0 )
lln = strlen( ln );
while(( strlen( ln0 ) > 0 ) && ( strncmp( ln0, ln, lln ) != 0 ))
dir = dirLfnNext( ln0 );
SdFile::dirName( dir, sn );
return strlen( sn ) != 0;
// Convert a 'long name' path to a 'short name' path
// parameters:
// char * snd : where to store the 'short name' path
// char * lnd : the 'long name' path we want to convert
// size_t maxsnl : the length of snd string
// return:
boolean l2sPath( char * snd, char * lnd, size_t maxsnl )
char * dir0 = lnd + 1;
char * dir1;
char * snd1;
strcpy( snd, "/" );
while( strlen( dir0 ) > 1 )
dir1 = strchr( dir0, '/' );
if( dir1 == 0 )
return true;
if( maxsnl <= strlen( snd ) + 8 )
return false;
snd1 = strrchr( snd, 0 );
// same as: snd1 = snd + strlen( snd );
if( ! l2sName( snd1 , snd, dir0, dir1 - dir0 ))
return false;
strcat( snd, "/" );
dir0 = dir1 + 1;
return true;
// Convert a long full name (path+name) to a short full name
// parameters:
// char * sfn : where to store the short full name
// char * lfn : the long full name we want to convert
// size_t maxsfn : the length of sfn string
// return:
boolean l2sFullName( char * sfn, char * lfn, size_t maxsfn )
if( ! l2sPath( sfn, lfn, maxsfn ))
return false;
char * sfn1 = strrchr( sfn, 0 );
char * ln = strrchr( lfn, '/' ) + 1;
if( ln == 0 )
return false;
return l2sName( sfn1, sfn, ln );
// DEMONSTRATE THE USE OF PREVIOUS FUNCTIONS
// You must modify content of strings theDir , theLongNameDir , theLongName
// and theLongFullName according to content of your SD card
Serial.begin( 9600 );
// Control Select of SD card of MP3 shield set to high
pinMode( SD_CS_PIN, OUTPUT );
digitalWrite( SD_CS_PIN, HIGH );
if( ! sd.begin( SD_CS_PIN ))
sd.initErrorHalt();
// Demonsrate use of dirLfnFirst() and dirLfnNext()
char * theDir = "/THEBEA~1/PLEASE~1/";
Serial.println( "List all files by their long name in directory" );
Serial.println( theDir );
Serial.println( "given by his short name:" );
Serial.println( );
char fileName[131];
dirLfnFirst( fileName, theDir );
while( strlen( fileName ) > 0 )
Serial.println( fileName );
dirLfnNext( fileName );
// Demonsrate use of l2sPath(), dirLfnFirst() and dirLfnNext()
// Show use of returned dir object to recover short name
char * theLongNameDir = "/The Beatles/Please Please Me/";
Serial.println( ); Serial.println( );
Serial.println( "List all files by their short and long names in directory" );
Serial.println( theLongNameDir );
Serial.println( "given by his long name:" );
Serial.println( );
char shortPath[100];
char shortName[13];
dir_t dir;
if( l2sPath( shortPath, theLongNameDir, 100 ))
dir = dirLfnFirst( fileName, shortPath );
SdFile::dirName( dir, shortName );
Serial.print( shortName );
Serial.print( " ; " );
dir = dirLfnNext( fileName );
Serial.println( " not found!" );
// Demonsrate use of l2sName()
char shortFileName[13];
char * theLongName = "07-Please Please Me.mp3";
Serial.println( "The short name of " );
Serial.println( theLongName );
Serial.println( "in directory" );
Serial.println( "is:" );
Serial.println( );
if( l2sName( shortFileName, theDir, theLongName ))
Serial.println( shortFileName );
Serial.println( "not found :(" );
// Demonsrate use of l2sFullName()
char * theLongFullName = "/The Beatles/Please Please Me/11-Do You Want To Know A Secret.mp3";
Serial.println( "The short full name of " );
Serial.println( theLongFullName );
Serial.println( );
if( l2sFullName( shortPath, theLongFullName, 100 ))
Serial.println( shortPath );
