How to read information with Modbus-RS485
In a few weeks I will receive a sensor with a modbus interface (RS485) for my work. Unfortunately I have no experience in modbus programming. I tried to document myself and I wrote this program. My arduino is used as master and the sensor as slave. I want to read at address 0x0001 the value of the water flow. In the datasheet it says: "Read out corresponding registers with function code 4 (0x04) (Read Input Registers)".
Am I on the right way or are there improvements to be made until I get the sensor back?
//#include <ArduinoRS485.h>
//#include <ArduinoModbus.h>
#include <ModbusMaster.h>
#define MAX485_DE 3   // Pin names that are connected between the MAX485 TTL to RS-485 converter module and Arduino UNO.
#define MAX485_RE_NEG 2
ModbusMaster node;                    //object node for class ModbusMaster
// preTrasnmission()  and postTrasmission() for making the Pins RE and DE of Max485 TTL to RS-485 convertor module high or low to Transmit or Receive data
void preTransmission()
  digitalWrite(MAX485_RE_NEG, 1);
  digitalWrite(MAX485_DE, 1);
void postTransmission()
  digitalWrite(MAX485_RE_NEG, 0);
  digitalWrite(MAX485_DE, 0);
  pinMode(MAX485_RE_NEG, OUTPUT);
  pinMode(MAX485_DE, OUTPUT);
  // intit receive mode
  node.begin(1, Serial);
  node.preTransmission(preTransmission);
  node.postTransmission(postTransmission);
  float valueSensor;
  valueSensor = node.readInputRegisters(0x0001, 1);
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
