How to read LCD display data with arduino?
how can i read the data of the below LCD display with arduino?
Display detail:
CS7106AGP
MKAR109721J
SEMICO
If you post clickable links to the documentation you will likely get help faster.
OP image.
Do you mean to intercept the data going from the chip to the LCD? Difficult, I would think. Can you connect to the analog input of the chip? What is the voltage range of the analog input?
Chinese data sheet (all I could find).
I do not think you can unless you interface directly to the display. It appears from the data sheet it is a is a 3 and a half A / D conversion circuit with direct drive LCD function simply stated a digital voltmeter on a chip.
