I woud like to read the serial data of my me-007 uls v1
(Datasheet)
The frame format seems very common:
1 start bit, 8 data bits, 1 stop bit at 9600 baud rate.
There are 6 hexadecimal frames. So how could this signal be read?
This code runs quite well for maxbotix-sensors (with ttl output)
[Reading serial data from maxSonar ultrasonic rangefinder - Sensors - Arduino Forum].
I would like to adapt the code for the me007 sensor, would that be possible with just a few changes?
Do you have any ideas which lines should be changed?
Sorry, I am an absolute Arduino beginner, thank's for your help.
/* test function to Parse data from MaxSonar serial data
and return integer */
#include <SoftwareSerial.h>
#define txPin 3 //define pins used for software serial for sonar
#define rxPin 2
SoftwareSerial sonarSerial(rxPin, txPin, true); //define serial port for recieving data, output from maxSonar is inverted requiring true to be set.
boolean stringComplete = false;
Serial.begin(9600); //start serial port for display
sonarSerial.begin(9600); //start serial port for maxSonar
delay(500); //wait for everything to initialize
int range = EZread();
if(stringComplete)
stringComplete = false; //reset sringComplete ready for next reading
Serial.print("Range ");
Serial.println(range);
//delay(500); //delay for debugging
int EZread()
int result;
char inData[4]; //char array to read data into
int index = 0;
sonarSerial.flush(); // Clear cache ready for next reading
while (stringComplete == false) {
//Serial.print("reading "); //debug line
if (sonarSerial.available())
char rByte = sonarSerial.read(); //read serial input for "R" to mark start of data
if(rByte == 'R')
//Serial.println("rByte set");
while (index < 3) //read next three character for range from sensor
inData[index] = sonarSerial.read();
//Serial.println(inData[index]); //Debug line
index++; // Increment where to write next
inData[index] = 0x00; //add a padding byte at end for atoi() function
rByte = 0; //reset the rByte ready for next reading
index = 0; // Reset index ready for next reading
stringComplete = true; // Set completion of read to true
result = atoi(inData); // Changes string data into an integer for use
return result;
