im currently using xbee to transfer data from one xbee to another. i have a total of 5 different data to be transfered to the another xbee. how can i read this data in another xbee
There are nowhere near enough details in your post. Are the XBees connected to Arduinos? If so, how? What kind of XBees are they? How are they configured?
the xbees are connected to the arduino rx-rx and tx-tx
xbee s1 is the type of xbee and they are configured using the x-ctu
by the way this the essential part of my code
on the sending part
const byte spiclk=17; // connect to ADXL CLK
const byte spimiso=16; // connect to ADXL DO
const byte spimosi=15; // connect to ADXL DI
const byte spics=14; // connect to ADXL CS
byte xyz[8]; // raw data storage
int x,y,z; // x, y, z accelerometer data
double fXg = 0; // x, y, z accelerometer data in degrees
double fYg = 0;
double fZg = 0;
const float alpha = 0.5;
byte spiread;
void setup(void){
Serial.begin(9600); // serial i/o for test output
init_adxl(); // initialize ADXL345
void loop(void){
read_xyz(); // read ADXL345 accelerometer
// and then send results to serial port
// view results by using IDE Tools>Serial Monitor
Serial.print("x = ");
Serial.print(x);
Serial.print(" y = ");
Serial.print(y);
Serial.print(" z = ");
Serial.println(z);
double pitch, roll;
//Low Pass Filter
fXg = x * alpha + (fXg * (1.0 - alpha));
fYg = y * alpha + (fYg * (1.0 - alpha));
fZg = z * alpha + (fZg * (1.0 - alpha));
//Roll & Pitch Equations
roll = (atan2(-fYg, fZg)180.0)/M_PI;
pitch = (atan2(fXg, sqrt(fYgfYg + fZg*fZg))*180.0)/M_PI;
Serial.print(" pitch = ");
Serial.print(pitch);
Serial.print(":");
Serial.print(" roll = ");
Serial.print(roll);
Serial.print(" ");
while (pitch && roll == 0 ){
if (pitch>45 && roll<45 && roll>-45){Serial.print(" moving north "); }
if (pitch<-45 && roll<45 && roll>-45){Serial.print(" moving south ");}
if (pitch<45 && pitch>-45 && roll>45 ){Serial.print(" moving east ");}
if (pitch<45 && pitch>-45 && roll<-45 ){Serial.print(" moving west ");}
if ( pitch<45 && pitch>-45 && roll<45 && roll>-45 ){Serial.print(" IDLE STATE ");}
void spi_out(byte spidat){
byte bitnum=8;
spiread=0;
// start spi bit bang
while(bitnum>0){
pinMode(spiclk,OUTPUT); // SPI CLK =0
if((spidat & 0x80)!=0)
pinMode(spimosi,INPUT); // MOSI = 1 if MSB =1
pinMode(spimosi,OUTPUT); // else MOSI = 0
spidat=spidat<<1;
pinMode(spiclk,INPUT); // SPI CLK = 1
// read spi data
spiread=spiread<<1;
if(digitalRead(spimiso)==HIGH) spiread |= 0x01; // shift in a 1 if MISO is 1
pinMode(spimosi,INPUT); // reset MOSI to 1
bitnum--;
/* Initialize ADXL345 */
void init_adxl(void){
delay(250);
pinMode(spics,OUTPUT); // CS=0
//Write to register 0x31, DATA FORMAT
spi_out(0x31);
// uncomment your desired range
spi_out(0x0B); //full resolution, +/- 16g range
//spi_out(0x0A); //full resolution, +/- 8g range
//spi_out(0x09); //full resolution, +/- 4g range
// spi_out(0x08); //full resolution, +/- 2g range
pinMode(spics,INPUT); //CS HIGH
delay(1);
// Write to register 0x2d, POWER_CTL
spi_out(0x2d);
//set to measure mode
spi_out(0x08);
delay(1);
Read all 3 axis x,y,z
void read_xyz(void){
int i;
//Set start address to 0x32
//D7= 1 for read and D6=1 for sequential read
spi_out(0xF2);
// dump xyz content to array
for(i=0;i<6;i++){
spi_out(0x00);
xyz*=spiread;*
// merge to convert to 16 bits*
x=((int)xyz[1]<<8) + xyz[0];*
y=((int)xyz[3]<<8) + xyz[2];*
z=((int)xyz[5]<<8) + xyz[4];*
pinMode(spics,INPUT); //CS HIGH*
and this is code for the receiving part
int pitch=0;
int roll=0;
int pitch2,roll2;
void loop() { -
if (Serial.available()>0){Serial.write(Serial.read());pitch2=pitch;}*
while (pitch && roll == 0){if (pitch>45 && roll<45 && roll>-45){Serial.print(" moving north2 "); }*
if (pitch<-45 && roll<45 && roll>-45){Serial.print(" moving south2 ");}*
if (pitch<45 && pitch>-45 && roll>45 ){Serial.print(" moving east2 ");}*
if (pitch<45 && pitch>-45 && roll<-45 ){Serial.print(" moving west2 ");}*
if ( pitch<45 && pitch>-45 && roll<45 && roll>-45 ){Serial.print(" IDLE STATE2 ");}*
pitch2=pitch; // i have put this so that i can check whether the xbee can understand the data receive individually
Serial.print(pitch2);*
roll2=roll;*
Serial.print(roll2);*
delay(250);}*
how can i get the multiple data transmitted by the sender and make the receiver part understand it individually. Thank you for your time reading this post
I really don't think that shifting data by 8) positions is going to prove useful. There are sticky posts at the top of the forum. You need to read them.
Too stupid for words. ONE STATEMENT PER LINE.
pitch2=pitch;
Now, explain this. If there is serial data to read, read and print it, but don't actually use it.
Why bother sending it?
If pitch is not 0, and roll is, enter an infinite loop. How useful. Perhaps NOW you can see why ONE STATEMENT PER LINE, and proper placement of { is SO important.
Are you using the Serial port to talk to the XBee OR to talk to the PC? Both is the wrong answer. So is yes.
actually im currently testing it first in the PC first so that i can see the results first if it can read the data incoming.
If it pass i shall place the replace the
and others with
Driveforward();}
void Driveforward(){
digitalWrite(RightMotorForward, HIGH);
digitalWrite(LeftMotorForward, HIGH);
digitalWrite(RightMotorReverse,LOW);
digitalWrite(LeftMotorReverse, LOW);
what im currently confused right now is that how can i read the multiple variables being sent by the transmitter and put them into their right position in which there will be no overlap of data with one another.
roll<45 && roll>-45
How is >-45 interpreted? Is -50, or -40, greater than -45?
Just wondering.
Forget about how you intend to use the data. Write a sketch that simply reads the data from the XBee (using a SoftwareSerial instance and two pins other than 0 and 1) and prints it using the Serial.print() method.
Open the Serial Monitor application, and show us the data that you get.
When you know what the data looks like, you can write code to save the data for parsing.
When that works, you can write the code to parse the data.
When that works, you can put your infinite loops back in place.
this is the data i get in the serial monitor using the codes i have use
in this i cant see the
(" moving north2 ") and others
which will make me did not understand whether the xbee can understand the pitch =(pitch data transmit) or it just understand that it is the just 2nd data transmit
CrossRoads
i think something like this
-45<roll<45
roll is between -45 and 45
if my memory serves it right the arduino did not take my
-45<roll<45
or i just happen not to do it right so i put it like this
roll<45 && roll>-45
When you decide to ditch that crappy code, and do what I suggested, I'll pay attention again.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// set the data rate for the SoftwareSerial port
mySerial.begin(9600);
void loop() // run over and over
Serial.println("Goodnight moon!");
mySerial.println("Hello, world?");
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
only the
("Goodnight moon!")
return to the serial monitor but the
("Hello, world?")
did not, can i ask why it did not return?
i have connected the rx-tx to the pins 10 and 11 and that is the result
i have also tried if rx-tx is connected to the rx-tx(pin 0 and 1) but it still displays the same result
can you please enlightened me.
Return from where? You sent that data to pins 10 and 11. You may, or may not, have something connected to those pins. That device may, or may not, read the data. That device may, or may not return something.
The RX and TX pins of what?
while (!Serial) {
Do you have a Leonardo? If not, why is this code here?
What we have here is a failure to communicate.
What did you set MY and DL to on the first XBee?
What did you set MY and DL to on the second XBee?
Are the PAN ID settings the same on both XBees?
