How to read multiple sensor and send the data to ThingSpeak?
Hello, I have a problem with my code. When I test it without ThingSpeak library, my sensor values (especially for analogRead on fireLevel dan gasLevel) are there (not 0). But when I use ThingSpeak library for send the data, the fireLevel dan gasLevel show 0 for the values. Any solutions for my code, thanks
I'm still learning
The sensor that I used:
  1. DHT11
  2. KY-026
  3. MQ-135
    and for the NodeMCU I used ESP32 type
#include <WiFi.h>
#include "ThingSpeak.h"
#include <SPI.h>
#include <Wire.h>
#include <DHT.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
const char* ssid = "SECRET_SSID";
const char* password = "SECRET_PASS";
WiFiClient client;
unsigned long channelNum = X;
const char* APIKey = "SECRET";
unsigned long lastTime = 0;
unsigned long timerDelay = 15000;
#define AIRQ_SENSOR 2 // ESP32 pin GIP2 connected to mq135 sensor
#define DHT_SENSOR_PIN  13 // ESP32 pin GIOP13 connected to DHT11 sensor
#define DHT_SENSOR_TYPE DHT11
// #define FIRE_SENSOR_DIGITAL 25 // ESP32 pin GIP25 connected to Fire sensor
#define FIRE_SENSOR_ANALOG 14 // ESP32 pin GIP14 connected to Fire sensor
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET     4 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
DHT dht_sensor(DHT_SENSOR_PIN, DHT_SENSOR_TYPE);
float humi, tempC, gasLevel, fireLevel;
String quality = "";
const uint8_t bitmap19[] = {0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x1c, 0x00, 0x00, 0x1c, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x3f, 0x00, 0x00, 0x3f, 0x40, 0x00, 0x7f, 0x60, 0x00, 0xff, 0xe0, 0x00, 0xff, 0xf0, 0x06, 0xff, 0xf0, 0x07, 0xff, 0xf8, 0x07, 0xff, 0xf8, 0x0f, 0xf7, 0xf8, 0x0f, 0xe7, 0xf8, 0x1f, 0xe3, 0xfc, 0x1f, 0xc1, 0xfc, 0x3f, 0x80, 0xfc, 0x3f, 0x80, 0xf8, 0x1f, 0x00, 0xf8, 0x1f, 0x00, 0xf0, 0x0f, 0x00, 0xe0, 0x07, 0x80, 0xc0, 0x01, 0x81, 0x00};
  dht_sensor.begin(); // initialize the DHT sensor
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3c)) { // Address 0x3D for 128x64
    Serial.println(F("SSD1306 allocation failed"));
  display.clearDisplay();
  display.setTextColor(WHITE);
  display.setTextSize(2);
  display.setCursor(50, 0);
  display.println("Air");
  display.setTextSize(1);
  display.setCursor(23, 20);
  display.println("Quality Monitor");
  display.display();
  delay(1200);
  WiFi.mode(WIFI_STA);
  ThingSpeak.begin(client);
void fireSensor() {
  fireLevel = analogRead(FIRE_SENSOR_ANALOG);
  Serial.println("fire level: " + String(fireLevel));
  if(fireLevel < 2000) {
    display.drawBitmap(90, 35, bitmap19, 24, 24, 1);
  else {
void temphSensor() {
  // read humidity
  humi  = dht_sensor.readHumidity();
  // read temperature in Celsius
  tempC = dht_sensor.readTemperature();
  // check whether the reading is successful or not
  if ( isnan(tempC) || isnan(humi)) {
    Serial.println("Failed to read from DHT sensor!");
    display.setCursor(0, 35);
    display.println("Tmp:");
    display.setCursor(30, 35);
    display.println(tempC);
    display.setCursor(64, 35);
    display.println("C");
    display.setCursor(0, 50);
    display.println("RH:");
    display.setCursor(30, 50);
    display.println(humi);
    display.setCursor(64, 50);
    display.println("%");
void airqSensor() {
  gasLevel = analogRead(AIRQ_SENSOR);
  Serial.println("gas Level: " + String(gasLevel));
  if(gasLevel < 500) {
    quality = "Good";
  else if(gasLevel < 750) {
    // avg 750
    quality = "Moderate";
  else if(gasLevel < 1500) {
    // avg 1500
    quality = "Unhealty";
  else {
    // 2000 >
    quality = "Hazardous";
  display.setCursor(30, 5);
  display.println("Air Quality");
  display.setCursor(35, 20);
  display.println(quality);
void writeThingSpeak() {
  // ThingSpeak.setField(1, tempC);
  // ThingSpeak.setField(2, humi);
  // ThingSpeak.setField(3, gasLevel);
  // ThingSpeak.setField(4, fireLevel);
  ThingSpeak.writeField(channelNum, 1, tempC, APIKey);
  ThingSpeak.writeField(channelNum, 2, humi, APIKey);
  ThingSpeak.writeField(channelNum, 3, gasLevel, APIKey);
  ThingSpeak.writeField(channelNum, 4, fireLevel, APIKey);
  // int x = ThingSpeak.writeFields(channelNum, APIKey);
  // if(x == 200) {
  //   Serial.println("Channel update successful.");
  // else {
  //   Serial.println("Problem updating channel. HTTP error code " + String(x));
  lastTime = millis();
  if(WiFi.status() != WL_CONNECTED){
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    while(WiFi.status() != WL_CONNECTED){
      WiFi.begin(ssid, password);  // Connect to WPA/WPA2 network. Change this line if using open or WEP network
      Serial.print(".");
      delay(5000);
    Serial.println("\nConnected.");
  fireSensor();
  airqSensor();
  temphSensor();
  display.display();
  writeThingSpeak();
Try to uncomment this diagnostic in your code and see what it will output.
