How to read multiple values of serial bytes in adruino?
I am using an android phone as a remote control for the robot, I send commands via bluetooth using these codes:
char c = 'f';
int y = 2;
byte[] com = new byte[2];
com[0] = (byte) c;
com[2] = (byte) y;
The arduino clone then receives the command and reads them:
char c;
int y;
if(Serial.available() > 0){
c = Serial.read();
switch(c){
case 'f':
y = Serial.read();
// do anything
Serial.println(y);
default:
the problem is, it can't read separate values of the bytes being sent, I checked the serial monitor and it displays the value of the variable y and another negative value, can someone here help me? =(
    c = Serial.read();
switch(c){
    case 'f':
    y = Serial.read();
    // do anything
    Serial.println(y);
    default:
If there is one byte to read, read both of them. I don't think that works too well. Apparently, you don't either.
Why don't you fix it?
    c = Serial.read();
char c now contains a byte of data, Serial.read is the method you used to retrieve the data. You can make y = c; or print c directly. You are currently doing a second Serial.read without a test.
Call a function to handle the data or write them to a value for an ammount of bytes.
Something to try, test each character received for a 1 or 0.
int ledPin = 13;
  pinMode(ledPin, OUTPUT);
  Serial.println("serial on/off test 0021"); // so I can keep track
  char c = 0;
  if (Serial.available() > 0)
    c = Serial.read();
    if (c == '1')     // assuming you send character '1', not a byte with value 1
       digitalWrite(ledPin, HIGH);
    if (c == '0')
       digitalWrite(ledPin, LOW);
