How to read register value from ADXL345 Eval board?
johnwasser:
The ADXL345 Evaluation Board is NOT a good choice if you want to connect the ADXL345 to an Arduino UNO. You should buy an ADXL345 on a breakout board:
http://www.sparkfun.com/products/9836
this i am understand..because i saw plenty of people using this for that....but i just want to ask that whether this eval board can do that also?because i hope i can done it with this eval board. is this possible?
tlslaj0417:
i just want to ask that whether this eval board can do that also? because i hope i can done it with this eval board. is this possible?
The Eval Board has an ATmega chip connected to the ADXL chip. There is no place on the Eval Board designed to bypass the on-board ATmega and connect the ADXL to an Arduino UNO. To do that properly you need a board designed to be connected to an Arduino UNO, like the breakout board I mentioned.
johnwasser:
tlslaj0417:
thanks for your information. i will discuss with my partner regarding this...would you mind i contact u in pm onwards if i meet any problem?thanks for you information for all of these :slight_smile:
If you encounter a problem you should post a new question on the forum. That way it will be searchable by others that might have a similar problem in the future.
johnwasser:
is ok thanks. i will repost it if i meet another problem thanks!!
