Hi there! I am having a problem on how to read and process each of the element in the array.
I will receive a message something like {Q, "senID": "AB", "destID": "OE", Hello world }
There are four different element. How do I read them separately? I get confused on the use of array for arduino.
Thanks in advance!
Check out strtok(). With this example program:
#include <string.h>
const char szStr[] = "{Q, \"senID\": \"AB\", \"destID\": \"OE\", Hello world }";
const char s[2] = "\"";
char *token;
Serial.begin( 115200 );
/* get the first token */
token = strtok(szStr, s);
/* walk through other tokens */
while( token != NULL )
Serial.println( token );
token = strtok( NULL, s );
}//setup
}//loop
you can break down the string into sub-strings, delimited by, say, the ‘"’ character. The output to the serial monitor:
{Q,
senID
AB
destID
OE
, Hello world }
What parts are you trying to extract? It seems like an odd structure…
I am doing LoRa communication project, so it is the message between nodes.
I wanted to split them into four part, so that I can read the source ID, destination ID and message correctly.
For example, I need to identify the source ID is AB at the receiver part..
The structure of message didn't change but the content did. I am confused on how do I extract them..
Please post the transmit and receive code, using code tags.
I haven’t completed my coding yet, I am just referring some coding which I don’t really understand. That’s why I am trying to write the script and I faced this problem.
May I know what code tags u are referring to?
String Routing[nodeClient+1][2] << for this one, can anyone help to explain what is the meaning of the for a string? The nodeClient is a variable as well.
re String Routing[nodeClient+1][2]
That is declaring a 2D array of Strings rows 0 to nodeClient, cols 0 to 1
i.e. two Strings for each node, see the code below
Check out my Taming Arduino Strings tutorial if you are using a lot of Strings
This code does the parsing using Arduino Strings
String input = "{Q, \"senID\": \"AB\", \"destID\": \"OE\", Hello world }";
const size_t nodeClient = 4;
String Routing[nodeClient+1][2];
for (int i = 10; i > 0; i--) {
Serial.print(' '); Serial.print(i);
// looking for " "
int startIdx = input.indexOf('"'); // the " char
while (startIdx >=0) {
startIdx += 1; // step over the "
int endIdx = input.indexOf('"',startIdx); // step over the starting " char
String word = input.substring(startIdx,endIdx);
Serial.println(word);
startIdx = input.indexOf('"',endIdx+1); // look for the next "
int counter = 1;
for(size_t i=0; i<=nodeClient; i++) {
Routing[i][0] = counter;
counter += 1;
Routing[i][1] = counter;
counter += 1;
Serial.print(Routing[i][0]); Serial.print(" "); Serial.println(Routing[i][1]);
The output is
senID
AB
destID
OE
1 2
3 4
5 6
7 8
9 10
