How to learn what file is written down by the last and how many all is written down files?
My task to learn what file is written down by the last and to show its contents to the display. The following purpose buttons up or down listing files. As I understand for this purpose it is necessary to know how many files is written down on the card.
vvadim:
I don't think that is right. The ReadWrite example in the IDE implies you just need to know the name of the file. If you don't know the name of the file, there is a listfiles programme in the same section.
If by display you mean the serial monitor, you might as well use Dumpfile. It is probably simpler as well as more appropriate.
Thanks Nick.
But files have names by date and they are created not every day. Therefore it is impossible to remember them.
It would be desirable to have function which, for example on pressing of the button, showed the written-down file, last on time.
By display I meant lcd 20 x 4.
I thought to make calculation of number of the written-down files.
But there is one problem - the file during the day corresponding to its name can be rewritten several times.
listfiles output all files from the first on time and date of creation and doesn't give the chance to count number of files on the card.
I can see my files in Serial but I can't touch them.
I understood that I won't be able to solve the problem with SD library.
Therefore started studying other libraries. And in SdFat found the solution on the basis of LongFileName example. Thanks to the author!
