How to read the output on a SN75ALS176?
Hello everyone.
I need to read the output on a SN75ALS176. I used the digitalRead() function, but the result was wrong. I appreciate your help.
Thank you in advance
NOTE:
The SN75ALS176 series differential bus transceivers are designed for bidirectional data
communication on multipoint bus transmission lines.
In my case this signal is a package with four digits inside. I suppose that this package can be reading through a function like digitalRead or something like this.
As a receiver, pin 1 is the output which goes to an Arduino input and read by digitalRead(). Pin 2 must be low to enable the receiver.
You are only reading one bit at a time so you'll need serial protocol (software and maybe some more hardware) to read serial data.
So what sort of signal is this?
Is it asynchronous serial data?
Is it synchronous serial data?
Is it a Manchester encoded data stream?
Is it a NRTZ encoded data stream?
Is it a PWM package?
Is it a PPM package?
These are just a few ways you can get a package with four digits inside.
Without knowing what you are trying to read then any answer is just guess work.
The fact that this signal comes through a SN75ALS176 is totally irrelevant.
laubia:
digitalRead reads a digital input pin once at the point its called. If there's some serial protocol coming in
on a pin you'll need code or hardware to handle that.
