How to read the voltage from from analogue port in PLC IDE in a way that it is not modified and is in ladder logic?
I have a transducer and when I did a simple sketch in C, I was getting readings that I think were not exactly what they should be. Some factoring etc was introduced.
I do not think so but have you read the guidelines and posted accordingly. What you want to do is but it is somewhat dependent on the ladder logic compiler. What do the examples show and the instructions should give you a clear idea. Reading the manual helps. Nobody wants to burn time running in a circle.
