How to read values from individual load cells?
Hello all,
To read output values from individual load cells, I have connected one load cell to one HX711 at a time (as shown in the following figure).
I have connected four such load cells to four HX711. GND pins of all HX711 are connected together to Arduino's GND pin. VCC pins of all four HX711 are connected together to Arduino's 5V pin. DT and SCK pins of each HX711 is connected to digital pins (2,3), (4,5), (6,7), (8,9).
DT pin of one HX711 is connected to digital pin 2
SCK pin of one HX711 is connected to digital pin 3
DT pin of second HX711 is connected to digital pin 4
SCK pin of second HX711 is connected to digital pin 5
and so on.....
I am using HX711 library by Olav Kallhovd. In this library, I am using calibration code to first calibrate all the load cells. How to modify the existing calibration code to read output values from each load cell.
The calibration code is attached as follows:
#include <HX711_ADC.h>
   HX711_ADC
   Arduino library for HX711 24-Bit Analog-to-Digital Converter for Weight Scales
   Olav Kallhovd sept2017
   This example file shows how to calibrate the load cell and optionally store the calibration
   value in EEPROM, and also how to change the value manually.
   The result value can then later be included in your project sketch or fetched from EEPROM.
   To implement calibration in your project sketch the simplified procedure is as follow:
       LoadCell.tare();
       //place known mass
       LoadCell.refreshDataSet();
       float newCalibrationValue = LoadCell.getNewCalibration(known_mass);
#if defined(ESP8266)|| defined(ESP32) || defined(AVR)
#include <EEPROM.h>
#endif
//pins:
const int HX711_dout = 3; //mcu > HX711 dout pin
const int HX711_sck = 2; //mcu > HX711 sck pin
//HX711 constructor:
HX711_ADC LoadCell(HX711_dout, HX711_sck);
const int calVal_eepromAdress = 0;
unsigned long t = 0;
  Serial.begin(57600); delay(10);
  Serial.println("Starting...");
  LoadCell.begin();
  //LoadCell.setReverseOutput(); //uncomment to turn a negative output value to positive
  unsigned long stabilizingtime = 2000; // preciscion right after power-up can be improved by adding a few seconds of stabilizing time
  boolean _tare = true; //set this to false if you don't want tare to be performed in the next step
  LoadCell.start(stabilizingtime, _tare);
  if (LoadCell.getTareTimeoutFlag() || LoadCell.getSignalTimeoutFlag()) {
    Serial.println("Timeout, check MCU>HX711 wiring and pin designations");
    while (1);
  else {
    LoadCell.setCalFactor(1.0); // user set calibration value (float), initial value 1.0 may be used for this sketch
    Serial.println("Startup is complete");
  while (!LoadCell.update());
  calibrate(); //start calibration procedure
  LoadCell.setTareOffset(0);
LoadCell.setSamplesInUse(1);
  static boolean newDataReady = 0;
  const int serialPrintInterval = 0; //increase value to slow down serial print activity
  // check for new data/start next conversion:
  if (LoadCell.update()) newDataReady = true;
  // get smoothed value from the dataset:
  if (newDataReady) {
    if (millis() > t + serialPrintInterval) {
      float i = LoadCell.getData();
      Serial.print("Load_cell output val: ");
      Serial.println(i);
      newDataReady = 0;
      t = millis();
  // receive command from serial terminal
  if (Serial.available() > 0) {
    char inByte = Serial.read();
    if (inByte == 't') LoadCell.tareNoDelay(); //tare
    else if (inByte == 'r') calibrate(); //calibrate
    else if (inByte == 'c') changeSavedCalFactor(); //edit calibration value manually
  // check if last tare operation is complete
  if (LoadCell.getTareStatus() == true) {
    Serial.println("Tare complete");
void calibrate() {
  Serial.println("***");
  Serial.println("Start calibration:");
  Serial.println("Place the load cell an a level stable surface.");
  Serial.println("Remove any load applied to the load cell.");
  Serial.println("Send 't' from serial monitor to set the tare offset.");
  boolean _resume = false;
  while (_resume == false) {
    LoadCell.update();
      _resume = true;
  Serial.println("Now, place your known mass on the loadcell.");
  Serial.println("Then send the weight of this mass (i.e. 100.0) from serial monitor.");
  float known_mass = 0;
  _resume = false;
    LoadCell.update();
      known_mass = Serial.parseFloat();
      if (known_mass != 0) {
        Serial.print("Known mass is: ");
        Serial.println(known_mass);
        _resume = true;
  LoadCell.refreshDataSet(); //refresh the dataset to be sure that the known mass is measured correct
  float newCalibrationValue = LoadCell.getNewCalibration(known_mass); //get the new calibration value
  Serial.print("New calibration value has been set to: ");
  Serial.print(newCalibrationValue);
  Serial.println(", use this as calibration value (calFactor) in your project sketch.");
  Serial.print("Save this value to EEPROM adress ");
  Serial.print(calVal_eepromAdress);
  Serial.println("? y/n");
  _resume = false;
      if (inByte == 'y') {
        EEPROM.begin(512);
#endif
        EEPROM.put(calVal_eepromAdress, newCalibrationValue);
        EEPROM.commit();
#endif
        EEPROM.get(calVal_eepromAdress, newCalibrationValue);
        Serial.print("Value ");
        Serial.print(" saved to EEPROM address: ");
        Serial.println(calVal_eepromAdress);
        _resume = true;
      else if (inByte == 'n') {
        Serial.println("Value not saved to EEPROM");
        _resume = true;
  Serial.println("End calibration");
  Serial.println("To re-calibrate, send 'r' from serial monitor.");
  Serial.println("For manual edit of the calibration value, send 'c' from serial monitor.");
void changeSavedCalFactor() {
  float oldCalibrationValue = LoadCell.getCalFactor();
  Serial.print("Current value is: ");
  Serial.println(oldCalibrationValue);
  Serial.println("Now, send the new value from serial monitor, i.e. 696.0");
  float newCalibrationValue;
      newCalibrationValue = Serial.parseFloat();
      if (newCalibrationValue != 0) {
        Serial.print("New calibration value is: ");
        Serial.println(newCalibrationValue);
        LoadCell.setCalFactor(newCalibrationValue);
        _resume = true;
  _resume = false;
        EEPROM.begin(512);
#endif
        EEPROM.commit();
#endif
        _resume = true;
        _resume = true;
  Serial.println("End change calibration value");
Use arrays to avoid having your code grow to 4 times it's current size. I'll start you off:
//pins:
const int HX711_dout[4] = {2, 4, 6, 8};
const int HX711_sck[4] = {3, 5, 7, 9};
HX711_ADC LoadCell[4] = {
  HX711_ADC(HX711_dout[0], HX711_sck[0]),
  HX711_ADC(HX711_dout[1], HX711_sck[1]),
  HX711_ADC(HX711_dout[2], HX711_sck[2]),
  HX711_ADC(HX711_dout[3], HX711_sck[3])
  for (int j=0; j<4; j++) {
    LoadCell[j].begin();
This is how my code looks like now:
   HX711_ADC
       LoadCell.tare();
       //place known mass
#include <EEPROM.h>
#endif
//pins:
const int HX711_dout[4] = {2,4,6,8}; //mcu > HX711 dout pin
const int HX711_sck[4] = {3,5,7,9} ; //mcu > HX711 sck pin
HX711_ADC LoadCell[4] ={
  LoadCell[j].start(stabilizingtime, _tare);
  if (LoadCell[j].getTareTimeoutFlag() || LoadCell[j].getSignalTimeoutFlag()) {
    while (1);
  else {
    LoadCell[j].setCalFactor(1.0); // user set calibration value (float), initial value 1.0 may be used for this sketch
  while (!LoadCell[j].update());
  LoadCell[j].setTareOffset(0);
LoadCell[j].setSamplesInUse(1);
  if (LoadCell[j].update()) newDataReady = true;
  if (newDataReady) {
      float i = LoadCell[j].getData();
      Serial.println(i);
      newDataReady = 0;
      t = millis();
    if (inByte == 't') LoadCell[j].tareNoDelay(); //tare
  if (LoadCell[j].getTareStatus() == true) {
void calibrate() {
    LoadCell[j].update();
      _resume = true;
  _resume = false;
        _resume = true;
  LoadCell[j].refreshDataSet(); //refresh the dataset to be sure that the known mass is measured correct
  float newCalibrationValue = LoadCell[j].getNewCalibration(known_mass); //get the new calibration value
  _resume = false;
        EEPROM.begin(512);
#endif
        EEPROM.commit();
#endif
        _resume = true;
        _resume = true;
        LoadCell[j].setCalFactor(newCalibrationValue);
        _resume = true;
  _resume = false;
        EEPROM.begin(512);
#endif
        EEPROM.commit();
#endif
        _resume = true;
        _resume = true;
Load cell value is not getting outputted on the serial monitor. What is wrong in my code? The code is as follows:
   HX711_ADC
       LoadCell.tare();
       //place known mass
#include <EEPROM.h>
#endif
//pins:
    while (1);
  else {
  if (newDataReady) {
      Serial.println(i);
      newDataReady = 0;
      t = millis();
void calibrate() {
      _resume = true;
  _resume = false;
        _resume = true;
  _resume = false;
        EEPROM.begin(512);
#endif
        EEPROM.commit();
#endif
        _resume = true;
        _resume = true;
        _resume = true;
  _resume = false;
        EEPROM.begin(512);
#endif
        EEPROM.commit();
#endif
        _resume = true;
        _resume = true;
