How to reassign Servo library disabled pins
Heya. I am working on an autonomous car using a Ping sensor and a Seeed Motor controller shield and having issues with the speed controller pins. The speed control runs off pins 9 and 10 per the below sketch, but those pins are disabled when using the Servo library. So I basically need to reassign the pins that are being used by the servo library. Can anybody help me out?
------ CODE -------
#include <Ping.h>
#include <Servo.h>
int pos = 78; // variable to store the servo position
int offset = 55;
Ping ping = Ping(7,0,0);
int distance=0;
int distRight=0;
int distLeft=0;
int distBack=0;
int distCenter=0;
int pinI1=8;//define I1 interface
int pinI2=11;//define I2 interface
int speedpinA=9;//enable motor A - THIS BREAKS
int pinI3=12;//define I3 interface
int pinI4=13;//define I4 interface
int speedpinB=10;//enable motor B - THIS BREAKS
int spead =100;//define the spead of motor
int spead2 =200;//define the spead of motor
int spead3 =150;//define the spead of motor
delay(4000);
neck.attach(6); // THIS IS THE KILLER
neck.write(pos); // tell servo to go to position in variable 'pos'
delay(2000);
pinMode(pinI1,OUTPUT);
pinMode(pinI2,OUTPUT);
pinMode(speedpinA,OUTPUT);
pinMode(pinI3,OUTPUT);
pinMode(pinI4,OUTPUT);
pinMode(speedpinB,OUTPUT);
//test();
//delay(4000);
void test(){
forward();
Serial.println("forward");
delay(2000);
backward();
Serial.println("backward");
delay(2000);
left();
Serial.println("left");
delay(2000);
right();
Serial.println("right");
delay(2000);
void pingFire(){
ping.fire();
Serial.print("Microseconds: ");
Serial.print(ping.microseconds());
Serial.print(" | Inches ");
Serial.print(ping.inches());
Serial.print(" | Centimeters: ");
Serial.print(ping.centimeters());
distance = ping.centimeters();
delay(20);
//I1 = right forward
//I4 = left forward
//I3 = left backward
//I2 = right backward
void forward()
analogWrite(speedpinA,spead);//input a simulation value to set the speed
analogWrite(speedpinB,spead);
digitalWrite(pinI4,HIGH);//turn DC Motor B move clockwise
digitalWrite(pinI3,LOW);
digitalWrite(pinI2,LOW);//turn DC Motor A move anticlockwise
digitalWrite(pinI1,HIGH);
void backward()//
digitalWrite(pinI4,LOW);//turn DC Motor B move anticlockwise
digitalWrite(pinI3,HIGH);
digitalWrite(pinI2,HIGH);//turn DC Motor A move clockwise
digitalWrite(pinI1,LOW);
void left()//
analogWrite(speedpinA,spead3);//input a simulation value to set the speed, back
analogWrite(speedpinB,spead2);
// digitalWrite(pinI2,LOW);//neutral motor
void right()//
// digitalWrite(pinI3,LOW);
digitalWrite(pinI2,LOW);//turn DC Motor A move clockwise
void coast()
digitalWrite(speedpinA,LOW);// Unenble the pin, to stop the motor. this should be done to avid damaging the motor.
digitalWrite(speedpinB,LOW);
//void stop()//
// analogWrite(speedpinA,spead);//input a simulation value to set the speed
// analogWrite(speedpinB,spead);
// digitalWrite(pinI4,LOW);//turn DC Motor B move anticlockwise
// digitalWrite(pinI3,HIGH);
// digitalWrite(pinI2,HIGH);//turn DC Motor A move clockwise
// digitalWrite(pinI1,LOW);
// delay(400);
void stop()//
//void sweep()
//{ // in steps of 1 degree
// myservo.write(pos + offset); // tell servo to go to position in variable 'pos'
// delay(500);
// pingFire();
// Serial.print("Left = ");
// Serial.println(distance);
// distLeft = distance;
// delay(500);
// myservo.write(pos - offset);
// delay(800);
// pingFire();
// Serial.print("Right = ");
// distRight = distance;
// delay(500);
// myservo.write(pos);
// delay(500);
// pingFire();
// Serial.print("Center = ");
// distCenter = distance;
// delay(500);
//void backup()
// myservo.write(pos + 89);
// delay(1200);
// pingFire();
// Serial.print("Reverse = ");
// delay(200);
// while (distance > 150) {
// backward();
// delay(500);
//void chooseDir()
// sweep();
// if ((distLeft < distRight) && distLeft >150) {
// left();
// } else if ((distLeft < distRight) && distLeft >150) {
// right();
// else {
// backward();
left();
delay(2000);
stop();
right();
delay(2000);
stop();
// delay(2000);
forward();
delay(2000);
stop();
backward();
delay(2000);
stop();
You can look at the datasheet to see the functionality of the microcontroller.
Do you use an Arduino Uno ? if so, you have the ATmega328p.
The microcontroller has timers, and lots of other things inside. When a certain timer is used by the Servo library, it can no longer be used for a PWM signal. Therefor pin 9 and 10 can no longer be used with analogWrite, but you can use them as normal pins and make them high and low or as input as you wish.
There are a few other pins for PWM (the analogWrite function). Can you change the pins ? for example pin 5 and 6 for the PWM signal ? Or else pin 3 and 11.
Pin 5 and 6 are something special. They share the timer with the millis() timing. So perhaps 3 and 11 is better.
There is an alternative servo library that uses timer2. Look for the ServoTimer2 library.
Cool so i found the Servo2 library and deployed it instead of the Servo in order to disable pins 3 and 11 instead of 9 and 10, but this causes a conflict between my Ping sensor and the Servo! How annoying. So instead i tried reinitiating the timer after i detach it to free up the pins, but that only allows one of the motors to turn from the motor controller! So weird! Any other thoughts on how to get the Ping, Motor Controller, and Servo working together?
