So I have a PCB with an LCD hooked up along with a 595 shift register. Unfortunately, when I designed the board I didn't realize that the LCD library used SPI, which on the Arduino Uno is pins 13-10. Therefore, the system overrides the pin 12 for the DHT and it returns nan.
The LCD library I used is here: Arduino Playground - LiquidCrystal Library
I've tried modifying the pins_arduino.h on line 40 to set the MISO pin to something else. When I debug the MISO value with serial it prints the value I set it to, however it has no effect on the DHT (still returns nan).
So I'm in a sticky situation because literally every single pin is in use except for 0 and 1, and I've everything is kind of set because I've already made my PCB.
Is it even possible to change the MISO pin, if so, am I going about it the right way?
