How to receive messages on Telegram using this library ?
I'm moving forward and getting to know the FastBot.h library a little more
msg.text are the messages we type in Telegram and send to, in my case, a NodeMCU 12E.
I would like the String phrase to be the same as the message I type, but only if it starts with 12345. For example:
I type this on Telegram: 12345my Telegram message
Then on the serial monitor I will see what sentence became 12345my Telegram message
Then I will find a way to cut 12345 leaving just the rest. Realize then that 12345 is just a kind of password so that the String phrase is equal to a specific message (and not any message).
Then I will limit the size of the message using length(). As it stands, the code below makes the String phrase equal to 12345. But that is not the objective. I need to add free text to 12345.
//https://github.com/GyverLibs/FastBot/tree/main
#define WIFI_SSID "AAAAAA"
#define WIFI_PASS "BBBBBBB"
#define BOT_TOKEN "5653478678346909:AAHyfEJzNJGJKJRRRRHRElDSKbu4Q1f3Cmo"
#define CHAT_ID "6789994109"
#include <FastBot.h>
FastBot bot(BOT_TOKEN);
String frase;
  connectWiFi();
  bot.setToken(BOT_TOKEN);
  bot.setChatID(CHAT_ID);
  bot.attach(newMsg);
  bot.setBufferSizes(512, 512);
void newMsg(FB_msg& msg) {
  if (msg.text == "12345") {
        frase = msg.text;
        Serial.print("frase é: ");Serial.println(frase);
  bot.tick();
void connectWiFi() {
  delay(2000);
  WiFi.begin(WIFI_SSID, WIFI_PASS);
    Serial.print(".");
    if (millis() > 15000) ESP.restart();
  Serial.println("Connected");
Does anyone know how to do this ?
Thanks
What happens now? What responce do You get?
As it stands, the phrase code equals 12345 because the message I am typing on Telegram is 12345. I don't understand and I don't see how it would be typing 12345mysentence and the code accepting this addition. This is because the text of my sentence that I will type in front of the 12345, the Arduino code does not know. It would have to be something like this: "12345"+any text Anyway, I think it's going to be difficult
[image]
Sorry, I just don't get it. Maybe another day.
There is no reason to apologize. Let's wait. Who knows, maybe someone will come up with a good solution.
I solved it myself:
Only messages starting with 12345 sent from BOT telegram to Nodemcu will be accepted in the String phrase.
  if (msg.text != "0") {
        String mensagem = msg.text;
        Serial.print("mensagem é: ");Serial.println(mensagem);
         if(mensagem.indexOf("12345") != -1) {
           mensagem.remove(0, 5);
           frase = mensagem;
        msg.text = "";
        mensagem = "";
        frase = "";
Is Telegram is a real-time example for an instant messaging app?
in a blog that I came across the mentioned it as an instant message:
