my first exercise with python
arduino sketch:
float t = dht.readTemperature();
float h = dht.readHumidity()
bridge.put("temp", t);
bridge.put("umidi", h);
I would like a very simple python example
#!/usr/bin/python
thank you very much
Robin2
February 10, 2014, 1:49pm
2
Have you tried Googling "arduino python" and what did you find that might be useful?
...R
sonnyyu
February 10, 2014, 3:29pm
3
To receive parameters in python you could use sys.argv, use print sys.argv find out how.
At Arduino sketch side:
void insertdb() {
Process p;
p.begin("/mnt/sda1/mysql.py");
p.addParameter("1");
p.addParameter("32");
p.run();
http://forum.arduino.cc/index.php?topic=214431.msg1570756#msg1570756
thanks for the suggestions!
I'd like to see an example like:
$test= $client->get("temp");
echo $test;
but if it is possible written in python
Fortunately, I found a running system:
#!/usr/bin/python
import sys
sys.path.insert(0, '/usr/lib/python2.7/bridge/')
from bridgeclient import BridgeClient as bridgeclient
value = bridgeclient()
temperatura = value.get('temp')
umidita = value.get('umi')
print temperatura
print umidita
I hope it will be useful
