How to recieve string from USB serial device via Adobe Air and Arduino...
I'm looking for a hardware solution to communicate with a proximity sensor. I think it can be accomplished with your products.
Background: My client makes consumer products, one uses a proximity sensor to trigger the device.
My goal is to read input from a modified client product for a trade show kiosk. The product uses a proximity sensor which I must interface with Adobe Air.
The engineer says they can modify a unit to send a serial string over USB. It will have two wires coming out that can connect to a TTL to USB converter.
What I hope to find here is a product that can interface the product and produce a keyboard stroke as this is easy to listen for and react to in Adobe Air. In liue of a keyboard stroke, some other mechanism to monitor the sensor.
This is not something I am familiar with - any background information would be greatly appreciated.
I did find an AIR native extension (ANE) that provides access to serial port/RS232: https://code.google.com/p/as3-arduino-connector/
which led me to this forum.
Thanks for your advice!
C.
Have a look at the Leonardo as it can emulate keyboard/mouse.
From the Linked Page:
The Leonardo differs from all preceding boards in that the ATmega32u4 has built-in USB communication, eliminating the need for a secondary processor. This allows the Leonardo to appear to a connected computer as a mouse and keyboard, in addition to a virtual (CDC) serial / COM port. It also has other implications for the behavior of the board; these are detailed on the getting started page.
Can be done, and isn't even very difficult. This is flash (AS3) streaming to an Arduino Mega that I did in 4 evenings starting from scratch knowing NOTHING about Arduino (it was the first thing I ever did).
http://youtu.be/C_NY9YuSQzg?list=UU5POw6kR9q58_7ayAucV6TQ
But your description of what it is that you want to do is vague. Do you want 2-way or 1-way communication between the device and Adobe AIR ? Does it have to be a Wi-Fi connection, a wired connection or can it be a Bluetooth connection ?
There are many ways of getting data from a serial to Flash/Air/AS3 which you can find with Google.
For example the firmata library
http://www.instructables.com/id/Integrating-your-Arduino-With-Flash-and-Actionscri/
Or as3glue
as3glue (youtube)
Then there's the serial to socket solution
http://blog.arduino.cc/category/languages/libraries/serial-to-socket/
Or then you simply could use a bluetooth serial module (you do not need even an Arduino) to route the serial to a Bluetooth wireless serial
http://www.ebay.com/itm/Wireless-Serial-4-Pin-Bluetooth-RF-Transceiver-Module-HC-06-RS232-With-backplane-/200924726178
And grab it at the other end (the PC running AIR) using Glovepie, and turn it into keyboard strokes
http://glovepie.org/
Sorry to reply so late, if you use Android you can also use this: http://forum.arduino.cc/index.php?topic=313979.0
It let's an Air Android app connect to an Arduino using the USB Host, no permissions are required
