how to rectifiy the 100 Khz sine wave signal
hi friends, i have 5V peak to peak output 100 Khz sine wave signal from sensor, i want to rectify this signal as DC how i can achieve this task. please help me
A diode is often used to rectify signals.
If you want to read the signal directly with the ADC, then offset the signal by 2.5V DC, as shown in this AC voltage monitor circuit.
Full Wave Bridge Rectifier
D1 -D4 = 1n4001 diodes C = 470uF to 1000uF
(values based on low current load. Since load current or application were not specified, power supply cannot be designed specifically for a load that was not specified.
Depends what you want to do with that signal. Only detect if it's there? Measure it's peak/peak voltage, or frequency? Is it a digital 0-5volt signal, or AC centered around ground?
@raschemmel A 1N400x is too slow for 100kHz. Leo..
Wawa: Depends what you want to do with that signal. Only detect if it's there? Measure it's peak/peak voltage, or frequency? Is it a digital 0-5volt signal, or AC centered around ground?
i want to measure peak to peak value its ac signal from xr2206
can i use UF4007 diode to rectify this signal
Try 1N4148 (1N914), experiment with output capacitors and load values.
Yes, a 1N4148 would be better And reduce the buffer cap to 100n. Leo..
100,000 Hz/60 Hz = 1666
1000 uF/1666 = 0.6 uF
Smoothing cap value needed depends on load resistor value (you need one). If there is no load (very high impedance input pin), then rectified voltage on the cap will stay there for a long time. As larryd said: experiment with output capacitors and load values.
You might not need a full bridge if XR2206 and Arduino grounds are shared. Leo..
Do you have an accuracy goal. With a 5V P-P signal the diode drop 0.3 to 0.5 v is a large portion of you signal. Is that adequate for what you need?
There are precision rectifier circuits which basically is an opamp with the diode inside the feedback loop. For a 100k Hz you would have to carefully choose your components.
At least use schottky diodes to rectify, not 1N4148 or 1N400x series!!
arulselvam: hi friends, i have 5V peak to peak output 100 Khz sine wave signal from sensor, i want to rectify this signal as DC how i can achieve this task. please help me
What sensor (link) and what are you going to do with the rectified result ? You may be able to attempt a signal processing treatment of your input signal eg subtracting 2.5 and returning the absolute value of the voltage, but an Arduino may be too slow for any elaborate processing here.
EXAR 2206
(Supply Voltage = 10Vdc, hence +/- 5V AC out)
Do you have an oscilloscope? - that's the obvious way...
Allan
