I found this little program on the web to save data sendt from the arduino to a textfile.
(http://electronics.stackexchange.com/questions/54/saving-arduino-sensor-data-to-a-text-file)
import processing.serial.*;
Serial mySerial;
PrintWriter output;
size(100, 100);
mySerial = new Serial(this, "COM3", 9600);
output = createWriter( "data.txt" );
void draw() {
if (mySerial.available() > 0 ) {
String value = mySerial.readString();
if ( value != null ) {
output.println( value );
On arduino is running a simple code:
Serial.println("Test-data..");
delay(200);
I get the following error in the processing terminal:
Error inside Serial.()
table Library
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
gnu.io.PortInUseException: Unknown Application
at gnu.io.CommPortIdentifier.open(CommPortIdentifier.java:354)
at processing.serial.Serial.(Unknown Source)
at sketch_130802a.setup(sketch_130802a.java:26)
at processing.core.PApplet.handleDraw(PApplet.java:2245)
at processing.core.PGraphicsJava2D.requestDraw(PGraphicsJava2D.java:243)
at processing.core.PApplet.run(PApplet.java:2141)
at java.lang.Thread.run(Thread.java:662)
Any help on why it’s not working is appreciated.
Best regards from Kresten
