How to Reduce the Detection Rate of HC-SR04 Ultrasonic Sensor?
Hi everyone,
I'm working on a project using the HC-SR04 ultrasonic sensor, and I need to reduce its detection rate. Currently, it detects objects with a probability of 0.9999, but I want to lower it to 0.5.
Is there a way to achieve this through software modifications (e.g., increasing delay, adjusting trigger frequency, or probabilistically skipping detections) or hardware adjustments (e.g., narrowing the field of view or reducing sensitivity)?
Any suggestions, code examples, or proven methods would be greatly appreciated!
Thanks in advance!
Hi, @mmudassir0164
Welcome to the forum.
Why?
What do you mean by detection rate?
0.9999 ????
Rate or accuracy of distance measurement?
What is you project?
Thanks.. Tom.... :smiley: :+1: :coffee: :australia:
  • Why are you needing to do this.
  • Maybe cover the sender a bit to lower its output level.
For every ping, read the echo only if (random(2) == 1);
That would be easy. Just use the random() function.
Yes that will do it.
1.That sounds like it could be an interesting project that could be a lot of fun! However, please keep in mind that we are not a free design or code-writing service. We’re more than happy to help with your design or code, but we need you to make an initial attempt. Please design and write your code, then post it along with an explanation of what’s not working properly.
  1. Show Your Work First: Before asking for assistance, make an attempt to design or write the code yourself. Share your work along with details about what isn’t working. Only you know what you want!
  2. Provide Clear Documentation: Since we can’t see your project, share an annotated schematic (best) or a clear drawing of your setup. Pictures are welcome, but avoid using Fritzing diagrams as they are wiring diagrams, not schematics, and are not ideal for troubleshooting.
  3. Include Technical Details: If there is specific hardware involved, include links to technical information. There are often many versions of similar components, so precise details are essential. What version of sensors and a processor are we looking at.
  4. Reference Resources: For additional help, check out useful links and tutorials: Useful Links on Arduino Forum. Post links to your sensors and the processors technical information.
  5. Obtain a copy: of the Arduino Cookbook and complete several of the projects. Many of them will help you achieve parts of your goals.**
  6. Course Electronics For Beginners (eBook)
  7. Electronics For Beginners (eBook)
  8. Arduino Step-by-step Projects Course | Build 25 Projects
Hi, @mmudassir0164
Please do not go back and edit posts after being asked questions.
Post your replies on a NEW post, this will not cause confusion when reading the thread later.
Thank you for your response!
To clarify, by detection rate, I mean the probability of detection (Pd)—the likelihood that the HC-SR04 sensor successfully detects an object when it should. Currently, in my setup, the detection rate is nearly 0.9999 (almost always detecting), but for my research, I need to experiment with lower detection probabilities, such as Pd = 0.5.
I am working on my MS thesis, where I am implementing a robotic search strategy. In simulations, I can control Pd mathematically, but at the experimental level, I need a way to manipulate the HC-SR04 sensor’s detection probability to match my simulations.
I am looking for software or hardware methods to reduce the probability of detection in a controlled manner. This could involve adjusting the trigger frequency, adding randomness to detection, modifying sensor placement, or other techniques.
Any insights on how to achieve this would be greatly appreciated! :rocket:
As already mentioned, accepting a detection with probability 0.5 works very well. Did you read those posts?
Trivial example:
if (object_detected) {
   if  (random(0,100) < 50) object_detected = false;
