How to refresh?
Hello everybody,
sorry newbie on the forum and cpp programing.
I only have a quick question on a demo downloaded from waveshare website for a ePaper display 2.13 inches black and white. I was able to add a second image with a delay time but I need to implement a refresh so the picture will run continuously until power source is dead. Any wisdom will be appreciated, thank you for any help and best regards.
  • @filename : epd2in13-demo.ino
  • @brief : 2.13inch e-paper display demo
  • @author : Yehui from Waveshare
  • Copyright (C) Waveshare September 9 2017
  • Permission is hereby granted, free of charge, to any person obtaining a copy
  • of this software and associated documnetation files (the "Software"), to deal
  • in the Software without restriction, including without limitation the rights
  • to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
  • copies of the Software, and to permit persons to whom the Software is
  • furished to do so, subject to the following conditions:
  • The above copyright notice and this permission notice shall be included in
  • all copies or substantial portions of the Software.
  • THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
  • IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
  • FITNESS OR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
  • AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
  • LIABILITY WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
  • OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
  • THE SOFTWARE.
#include <SPI.h>
#include "fepd2in13.h"
#include "imagedata.h"
  • Due to RAM not enough in Arduino UNO, a frame buffer is not allowed.
  • In this case, a smaller image buffer is allocated and you have to
  • update a partial display several times.
  • 1 byte = 8 pixels, therefore you have to set 8*N pixels at a time.
    Epd epd;
if (epd.Init() != 0) {
Serial.print("e-Paper init failed\n");
return;
//Serial.print("ClearFrameMemory\n");
// epd.ClearFrameMemory(); // bit set = white, bit reset = black
  • there are 2 memory areas embedded in the e-paper display
  • and once the display is refreshed, the memory area will be auto-toggled,
  • i.e. the next action of SetFrameMemory will set the other memory area
  • therefore you have to set the frame memory and refresh the display twice.
Serial.print("SetFrameMemory\n");
epd.SetFrameMemory(gImage_IMAGE);
Serial.print("DisplayFrame\n");
epd.DisplayFrame();
delay(5000);
epd.SetFrameMemory(gImage_IMAGE1);
epd.DisplayFrame();
epdif.cpp (1.97 KB)
epdif.h (1.83 KB)
fepd2in13.cpp (7.83 KB)
fepd2in13.h (2.14 KB)
fepd2in13-demo.ino (2.87 KB)
The code as shown, runs in setup , which only executes once as the start . You need code in the “loop” if want it to run continually .
Thank you!! I placed the code in between loop brackets and it runs continually.
my code keeps saying "exit status one" it keeps on until it eventually verifies my code, without me even changing a thing to my code. but it takes a day or two until it accepts my code :cry:
