How to register simultanious button press
Hi Guys,
I have a question I can’t seem to work out and not find a good example code for. There are 4 buttons and I would like to register if button 1 & 2 are pressed simultaniously. I can register the doubleclick. What I can not manage is to then bypass the single click functionality.
Probably something very obvious but how can I manage this?
#include <Arduino.h>
int nbts = 4;
int startpin = 14;
int bts[4];
boolean btgs[4];
boolean doubleClick = false;
void setup (){
  for (int i=0; i<nbts; i++) bts[i] = i+startpin;      // set the pin for the buttons
  for (int i=0; i<nbts; i++) btgs[i] = false;          // set booleans to false
  for (int i=0; i<nbts; i++) pinMode(bts[i], INPUT_PULLUP);   // pins to input_pullup
void loop () {
    for (int i=0; i<nbts; i++) {
      /////////////////// DOUBLE CLICK CODE /////////////////////////////
      if (!doubleClick) {
        if (digitalRead(bts[0])==LOW && digitalRead(bts[1])==LOW) {
          Serial.println("doubleclick");
          doubleClick = true;
      else {
        if (digitalRead(bts[0])==HIGH && digitalRead(bts[1])==HIGH) {
          Serial.println("doublerelease");
      /////////////////// SINGLE CLICK CODE /////////////////////////////
      if (!btgs[i]) {
        if (digitalRead(bts[i])==LOW) {
          Serial.println("bt" + String(i) + " pressed");
          btgs[i] = true;
      else {
        if (digitalRead(bts[i])==HIGH) {
          Serial.println("bt" + String(i) + " released");
          btgs[i] = false;
    delay(15);
Why do you need 3 for loops?
      if (!doubleClick) {
          doubleClick = true;
Why do you iterate 4 times, processing the same two pins?
First, you need to understand that nothing happens simultaneously on the Arduino. It is impossible to press two switches at the same time.
It is possible to press one switch, and then, while that switch is pressed, press another one.
So, the first thing you need to do is properly define your requirements.
Ok, thanks…
I got rid of the loops and iterations but the case remains… I should probably have something like:
  • first button is pressed
  • do nothing for a bit while checking if another button is pressed
  • if no other button is pressed → do task for pressed button
  • another button is pressed → do task for double press
but I still don’t know how to go about this…
int nbts = 4;
int startpin = 14;
int bts[4];
boolean btgs[4];
void setup (){
    pinMode(bts[i], INPUT_PULLUP);   // set pins to input_pullup
void loop () {
  if (digitalRead(bts[0])==LOW && digitalRead(bts[1])==LOW && !doubleClick) {
    doubleClick = true;
    return;
  else if (digitalRead(bts[0])==HIGH && digitalRead(bts[1])==HIGH && doubleClick) {
    return;
    if (!btgs[i] && !doubleClick) {
        btgs[i] = true;
    else {
      if (digitalRead(bts[i])==HIGH && !doubleClick) {
        btgs[i] = false;
  delay(15);
but I still don't know how to go about this....
List the steps YOU would follow, using a watch, a pencil, and a pad of paper.
Making the Arduino do something that you can not describe well is going to be extremely difficult.
You MUST stop using phrases like "for a bit". That either means "for a random amount if time" OR "for I really don't know how long". Dealing with each case is going to be VERY different.
The state change detection example bears looking at.
Try the below code, not tested.
int nbts = 4;
int startpin = 14;
int bts[4];
boolean btgs[4];
const int WAIT_TIME = 1000;
int lastClicked = 0;
void setup () {
  for (int i = 0; i < nbts; i++) {
    bts[i] = i + startpin;           // set the pin for the buttons
  if (digitalRead(bts[0]) == HIGH) {
    lastClicked = millis();
  if (digitalRead(bts[1]) == HIGH) {
    if (millis() - lastClicked <= WAIT_TIME) {
      doubleClick = true;
  if (millis() - lastClicked > WAIT_TIME && doubleClick == false)
    Serial.println("Single click");
  else if (doubleClick == true)
    Serial.println("Double Click");
  if (digitalRead(bts[0]) == LOW || digitalRead(bts[1]) == LOW) {
    lastClicked =0;
Some comments.
I always feel difficulty understanding condition checks like
if (!doubleClick)
instead, it will be more readable if you could write
if (doubleClick==false)
may be the difficulty only for me :slight_smile:
It is. I prefer to NOT see == true or == false in an if test.
PaulS: It is. I prefer to NOT see == true or == false in an if test.
:) so thats confirmed, it's only for me
Ok, thanks guys,
you put me on the right track with the wait time. Got it working now. Probably by far not the cleanest code but I’m gonna put some time into cleaning it up. Especially the somewhat clumsy delay at the end to get rid of the functionality for the last released button.
Here’s what’s working now:
int nbts = 4;
int startpin = 14;
int bts[4];
boolean btgs[4];
boolean timer = false;
const int WAIT_TIME = 150;
void setup () {
    if (digitalRead(bts[i]) == LOW) {       // if a button is pressed
      if (!timer) {                         // and if the timer is not running
        btgs[i] = true;                     // set buttonpress to on
        lastClicked = millis();             // set click time
        timer = true;                       // zet timer to on
    if (digitalRead(bts[0]) == LOW && digitalRead(bts[1]) == LOW) {     // if button 0 and 1 are pressed at the same time
      if (millis() - lastClicked <= WAIT_TIME) {                        // and it is done within the waiting time
        doubleClick = true;                                             // set double click to true
        btgs[i] = false;                                                // turn the pressed buttons off again
    if (millis() - lastClicked > WAIT_TIME && !doubleClick){            // if the waiting time is over and there is no doubleclick
      if (btgs[i])  {                                                   // and if a buttonpress is set to on
        if (digitalRead(bts[i])==HIGH) {                                //  and if the button is released again
          btgs[i] = false;                                              // turn buttonpress off
          timer = false;                                                // set timer to off
          Serial.println("bt" + String(i) + " released");               // print released button of do whatever is wanted here
    if (digitalRead(bts[0]) == HIGH || digitalRead(bts[1]) == HIGH) {   // if button 0 or 1 is released
      if (doubleClick) {                                                // and there is a double click
        doubleClick = false;                                            // set double click to false
        Serial.println("Double Click released");                        // print doubleclick released
        lastClicked =0;                                                 // stop the timer
  delay (100);                                                           // delay to get rid of press for the last released button
