How to reliable clear the dashboard message widget?
If I clear the message widget from Arduino code like this:
statusText = PropertyActions::CLEAR;
It always works But if I try to clear then write a new message like this:
statusText = "some message";
It always fails to clear first. A delay between doesn't help. I don't understand this!
Is there a way to clear then write to avoid long message lists?
Looks like I answer my own question. In the above example the second command overwrites the first clear command. The solution is to put ArduinoCloud.update(); in between like this:
Then it works as desired!
