How to remove a data from rfid card using mfrc522
Good Day everyone, can i ask something, how to delete data from rfid card using mfrc522 because i use this code for adding data in rfid:
int block=2;//this is the block number we will write into and then read. Do not write into 'sector trailer' block, since this can make the block unusable.
byte blockcontent[16] = {"SubScribe______"};//an array with 16 bytes to be written into one of the 64 card blocks is defined!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
//byte blockcontent[16] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};//all zeros. This can be used to delete a block.
byte readbackblock[18];//This array is used for reading out a block. The MIFARE_Read method requires a buffer that is at least 18 bytes to hold the 16 bytes of a block.
We just need to know how to remove data...
have you checked the examples provided with this mfrc522 library? (in particular have a look at rfid_write_personal_data)
