How to "remove" int from a list each interaction? -drink roulette
Hi to all… Im making a drink roulette, and I like to add some features at just turn and drink.
You can see the progress in here(Spanish)
The classic roulette turns and stops in any given time, but I want to make this to have the next feature;
Once is loaded, say 12 glasses, start… and stop lets say at 8 position.
So the next I want to make is to make the available random = {1…12} -8
I mean the position, so… if the glass with the drink number 8 has been taken… it will not be available for the next itereation…
So lets say…
Random = 8 //past shot
if random = (used spaces){
random again}
else random;
So… I let my code in here;
#include <Stepper.h>
const byte noise = A0;
const byte led = 13;
byte reverse_direction = 0;
int  analog_seed;
int  random_number = 0;
int  motor_number = 0;
boolean changue = false;                           //var to changue direction of stepper
const int stepsPerRevolution = 48;                 //steps per revolution
Stepper myStepper(stepsPerRevolution, 8,9,10,11);  //Pins to the stepper
void setup(){
  pinMode(led, OUTPUT);
  pinMode(noise,INPUT);
  myStepper.setSpeed(50);
void loop(){
  if(Serial.available() > 0){
    if(Serial.peek() == 'c'){  //chek for c to start code
      get_number_steps();
      switch_direction();
      myStepper.step(motor_number);
      Serial.print("El paso del motor es   "); Serial.println(motor_number);
      digitalWrite(led, HIGH);
      Serial.println("_______________________________");
  Serial.read();
int get_number_steps(){
    analog_seed =  analogRead(noise); //gets a value between 0 and 1023
    randomSeed(analog_seed);
    random_number = random(0,12);
    Serial.print("The aleatory number is "); Serial.println(random_number);
    motor_number = map(random_number, 0, 12, 0, 48);
 return motor_number;
int switch_direction(){
  if (changue == false){
     Serial.println("to the rigth ");
     changue = true;
  if(changue == true){
     Serial.println("To the left ");
     changue = false;
     motor_number =(motor_number) * ( -1);
I was thinking to use an bidimensional array
drinks [12][12]= {1,2,3,4,5,6,7,8,9,10,11,12}
{0,0,0,0,0,0,0,0,0, 0, 0, 0}
And let say …
Pseudocode;
random = random_number
//look for it on the array
if random_number == true{
//use for stepper
random_number = false; }
if random_number == false {
random() //again ???
Or more clearly how to discount an already used option from an array or a list.
If any one have any ideas, or the precise name for what I intent to do, please share, I will investigate… is for a good cause… a drinks roulette 8)
Thanks !
Give this a look at. Its a random number generator that produces a random number from a given set and it only gives a number that was not previously given.
It works great for small ranges but its not ideal for large ranges like 0 - 10000.
int randNumber;
#define Count 10
int list[Count];
byte i = 0;
boolean found = false;
  for (byte K = 0; K < 5; K++)
    for (int j = 0; j < Count; j++)
      list[j] = -1;
    randomSeed(K + 1);
    delay(50);
    i = 0;
    found = false;
    while (i < Count)
      randNumber = random(0, Count);
      for (byte L = 0; L < i; L++)
        found = false;
        if (list[L] == randNumber)
          found = true;
      if (!found)
        list[i] = randNumber;
        Serial.print(list[i]);
        Serial.print(",");
        i++;
HazardsMind: Give this a look at. Its a random number generator that produces a random number from a given set and it only gives a number that was not previously given.
Thanks a lot!!! I will read carefully !!! Will comeback with advances! :sunglasses:
Cheers!
Look up a "shuffle" algorithm.
http://en.wikipedia.org/wiki/Fisher-Yates_shuffle
Using that is like "shuffling" the drinks, and afterwards you get one at random.
for small numbers your array is good as it will need about 11 numbers to find a free one when bigger it is better to use a swap mechanism you have a big array 1000 places. the content is int from 1 to 1000 random says 234 now swap place of 234 and 1000 use the 234 so array[234] is 1000 and array [1000] =234 next random number is max 999 example 345 swap with 999 so array [345] is 999 and array [999]= 345 next random is max 998 etc. when max is 1 all are done, you have an array full with all numbers in reversed sequence. just reset the counter and start with a random array and put a second random
wow... in three responses and there is more than plenty to work with!
Thanks to all you!
I will give my self some time to read the different approaches, and will come back with something to discuss..
Again.. Thank you!
-Alex.
