how to remove stry 302
Hello everyone,
I have a coding problem and hope you can help me with it.
I copied part of the code from the Internet and programmed the rest myself. Everything worked out in the beginning and the program worked extremely well. It was only when I programmed a few lines of code to choose game mode that it started showing me error messages.
As I said, everything worked before that.
thank u very much!
here is the error message:
Arduino: 1.8.11 (Windows Store 1.8.29.0) (Windows 10), Board: "Arduino Uno"
mario:312:36: error: stray '\302' in program
     digitalWrite(LED_GREEN, HIGH); ´
mario:312:37: error: stray '\264' in program
mario:650:35: error: stray '\302' in program
       digitalWrite(BUZZER1, LOW); ´
mario:650:36: error: stray '\264' in program
mario:113:31: error: 'NOTE_E3' was not declared in this scope
   NOTE_C4, NOTE_FS4, NOTE_F4, NOTE_E3, NOTE_AS4, NOTE_A4,
C:\Users\rasla\OneDrive\Documents\Arduino\mario\mario.ino:113:31: note: suggested alternative: 'NOTE_E4'
                               NOTE_E4
C:\Users\rasla\OneDrive\Documents\Arduino\mario\mario.ino: In function 'void setup()':
mario:148:5: error: 'hallo' was not declared in this scope
     hallo();
C:\Users\rasla\OneDrive\Documents\Arduino\mario\mario.ino:148:5: note: suggested alternative: 'malloc'
     hallo();
     malloc
mario:150:5: error: 'gameMode' was not declared in this scope
     gameMode = MODE_MEMORY; // By default, we're going to play the memory game
C:\Users\rasla\OneDrive\Documents\Arduino\mario\mario.ino:150:5: note: suggested alternative: 'gameRound'
     gameRound
mario:179:5: error: 'updateMenu1' was not declared in this scope
     updateMenu1();
mario:180:5: error: 'loopi1' was not declared in this scope
     loopi1();
C:\Users\rasla\OneDrive\Documents\Arduino\mario\mario.ino:180:5: note: suggested alternative: 'loop'
     loopi1();
     loop
mario:190:5: error: 'updateMenu' was not declared in this scope
     updateMenu();
mario:191:5: error: 'loopi' was not declared in this scope
     loopi();
C:\Users\rasla\OneDrive\Documents\Arduino\mario\mario.ino:191:5: note: suggested alternative: 'loop'
     loopi();
     loop
C:\Users\rasla\OneDrive\Documents\Arduino\mario\mario.ino: In function 'void loop()':
mario:199:5: error: 'attractMode' was not declared in this scope
     attractMode();
mario:212:11: error: 'play_memory' was not declared in this scope
       if (play_memory() == true) {
C:\Users\rasla\OneDrive\Documents\Arduino\mario\mario.ino:212:11: note: suggested alternative: 'play_loser'
           play_loser
mario:228:7: error: 'play_battle' was not declared in this scope
       play_battle(); // Play game until someone loses
C:\Users\rasla\OneDrive\Documents\Arduino\mario\mario.ino: In function 'void toner(byte, int)':
mario:361:24: error: a function-definition is not allowed here before '{' token
   void playMoves(void) {
mario:370:29: error: a function-definition is not allowed here before '{' token
   boolean play_memory(void) {
mario:389:26: error: a function-definition is not allowed here before '{' token
   byte checkButton(void) {
mario:398:16: error: a function-definition is not allowed here before '{' token
   void loopi() {
mario:420:21: error: a function-definition is not allowed here before '{' token
   void updateMenu() {
mario:448:24: error: a function-definition is not allowed here before '{' token
   void executeAction() {
mario:462:18: error: a function-definition is not allowed here before '{' token
   void action1() {
mario:466:18: error: a function-definition is not allowed here before '{' token
   void action2() {
mario:470:18: error: a function-definition is not allowed here before '{' token
   void action3() {
mario:476:17: error: a function-definition is not allowed here before '{' token
   void loopi1() {
mario:498:22: error: a function-definition is not allowed here before '{' token
   void updateMenu1() {
mario:521:25: error: a function-definition is not allowed here before '{' token
   void executeAction1() {
mario:533:19: error: a function-definition is not allowed here before '{' token
   void action11() {
mario:539:19: error: a function-definition is not allowed here before '{' token
   void action22() {
mario:546:16: error: a function-definition is not allowed here before '{' token
   void hallo() {
mario:553:26: error: a function-definition is not allowed here before '{' token
   void attractMode(void) {
mario:585:29: error: a function-definition is not allowed here before '{' token
   boolean play_battle(void) {
mario:607:30: error: a function-definition is not allowed here before '{' token
   byte wait_for_button(void) {
exit status 1
Dieser Bericht wäre detaillierter, wenn die Option
"Ausführliche Ausgabe während der Kompilierung"
in Datei -> Voreinstellungen aktiviert wäre.
The carat (^) is pointing directly at the character to remove
problem solved. thx u very much
