How to remove the char divider in this library?
I'm using a DS3231 RTC and the default date reporting is in a dd.mm.yyyy format. I'm planning on using this as a variable for a SD card filename, it needs to be no more than 8 digits and contain no periods, however I have no idea where to start to remove these periods. I have been able to edit the library (attached) to change the '.' to a ' ', but it still leave me with a space. I've tried deleting the char divider portion entirely, but it doesn't compile afterwards. I've tried a few other things with the library but it won't compile after changes. I've never messed with the libraries before, but I'd rather have it output what I need than decoding it afterwards.
If this is not possible, or will screw up how the library works, how does one go about removing all instances of a character from a string?
Code:
// DS3231_Serial_Easy
// Copyright (C)2015 Rinky-Dink Electronics, Henning Karlsen. All right reserved
// web: http://www.RinkyDinkElectronics.com/
// A quick demo of how to use my DS3231-library to
// quickly send time and date information over a serial link
// To use the hardware I2C (TWI) interface of the Arduino you must connect
// the pins as follows:
// Arduino Uno/2009:
// DS3231:  SDA pin   -> Arduino Analog 4 or the dedicated SDA pin
//          SCL pin   -> Arduino Analog 5 or the dedicated SCL pin
// Arduino Leonardo:
// DS3231:  SDA pin   -> Arduino Digital 2 or the dedicated SDA pin
//          SCL pin   -> Arduino Digital 3 or the dedicated SCL pin
// Arduino Mega:
// DS3231:  SDA pin   -> Arduino Digital 20 (SDA) or the dedicated SDA pin
//          SCL pin   -> Arduino Digital 21 (SCL) or the dedicated SCL pin
// Arduino Due:
// DS3231:  SDA pin   -> Arduino Digital 20 (SDA) or the dedicated SDA1 (Digital 70) pin
//          SCL pin   -> Arduino Digital 21 (SCL) or the dedicated SCL1 (Digital 71) pin
// The internal pull-up resistors will be activated when using the
// hardware I2C interfaces.
// You can connect the DS3231 to any available pin but if you use any
// other than what is described above the library will fall back to
// a software-based, TWI-like protocol which will require exclusive access
// to the pins used, and you will also have to use appropriate, external
// pull-up resistors on the data and clock signals.
#include <DS3231.h>
// Init the DS3231 using the hardware interface
DS3231  rtc(SDA, SCL);
  // Setup Serial connection
  // Uncomment the next line if you are using an Arduino Leonardo
  //while (!Serial) {}
  // Initialize the rtc object
  rtc.begin();
  // The following lines can be uncommented to set the date and time
  //rtc.setDOW(WEDNESDAY);     // Set Day-of-Week to SUNDAY
  //rtc.setTime(12, 0, 0);     // Set the time to 12:00:00 (24hr format)
  //rtc.setDate(1, 1, 2014);   // Set the date to January 1st, 2014
  // Send Day-of-Week
  Serial.print(rtc.getDOWStr());
  Serial.print(" ");
  // Send date
  Serial.print(rtc.getDateStr());
  Serial.print(" -- ");
  // Send time
  Serial.println(rtc.getTimeStr());
  // Wait one second before repeating :)
  delay (1000);
The library has functions to extract all the time values separately. Just roll your own date time string from those.
Where did you get the library you are using?
I forgot to attach it, my bad. Its from rinkydinkelectronics.com
DS3231.h (3.04 KB)
OK. The getDateStr() function takes 3 optional arguments, including what separator to use between the values (the 3rd argument). None of the options defines whether to use to the delimiter, or not, so, you will need to follow aarg's advice and roll your own function.
With sprintf(), this is almost trivial.
