How to repair the avrdude.conf file.
I had tried to add the Attiny 4313 chip to avrdude.conf file to enable the chip to be programmed by the Arduino ISP . I am now unable to even use the blink program with the IDE. I have completely uninstalled and then re installed version 1.0.5. Still gives the same error messages. Is the avrdude.conf file hidden somewhere else on the system? Or is there something else going on?
This is a sample of the dump that is displayed when I use the verify button before loading the blink example. I have provided just a very short example of the messages.
C:\Program Files\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\standard C:\Users\Dell\AppData\Local\Temp\build4534022171523491304.tmp\BareMinimum.cpp -o C:\Users\Dell\AppData\Local\Temp\build4534022171523491304.tmp\BareMinimum.cpp.o
C:\Program Files\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\standard C:\Program Files\Arduino\hardware\arduino\cores\arduino\avr-libc\malloc.c -o C:\Users\Dell624\AppData\Local\Temp\build4534022171523491304.tmp\malloc.c.o
That's not an error message. How about copying and pasting the lot?
This is was most list of what I get when I just try to verify. As the output would roll by half of it was in RED letters. I was assuming it could not compile the blink program. After you stated that this is not an error I checked to see if there was a verbose option in the preferences. I did find that it was selected. I have now unchecked this option. So when I did reload the IDE software it did fix my issue just not the verbose setting. Now I need to figure out how to add the whole ATtiny family including the 4313. Moving forward life is good Thank you
C:\Program Files\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\standard C:\Users\Dell624\AppData\Local\Temp\build8877762333273966874.tmp\Blink.cpp -o C:\Users\Dell624\AppData\Local\Temp\build8877762333273966874.tmp\Blink.cpp.o
C:\Program Files\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\standard C:\Program Files\Arduino\hardware\arduino\cores\arduino\avr-libc\malloc.c -o C:\Users\Dell624\AppData\Local\Temp\build8877762333273966874.tmp\malloc.c.o
C:\Program Files\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\standard C:\Program Files\Arduino\hardware\arduino\cores\arduino\avr-libc\realloc.c -o C:\Users\Dell624\AppData\Local\Temp\build8877762333273966874.tmp\realloc.c.o
C:\Program Files\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\standard C:\Program Files\Arduino\hardware\arduino\cores\arduino\WInterrupts.c -o C:\Users\Dell624\AppData\Local\Temp\build8877762333273966874.tmp\WInterrupts.c.o
C:\Program Files\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\standard C:\Program Files\Arduino\hardware\arduino\cores\arduino\wiring.c -o C:\Users\Dell624\AppData\Local\Temp\build8877762333273966874.tmp\wiring.c.o
C:\Program Files\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\standard C:\Program Files\Arduino\hardware\arduino\cores\arduino\wiring_analog.c -o C:\Users\Dell624\AppData\Local\Temp\build8877762333273966874.tmp\wiring_analog.c.o
C:\Program Files\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\standard C:\Program Files\Arduino\hardware\arduino\cores\arduino\wiring_digital.c -o C:\Users\Dell624\AppData\Local\Temp\build8877762333273966874.tmp\wiring_digital.c.o
C:\Program Files\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\standard C:\Program Files\Arduino\hardware\arduino\cores\arduino\wiring_pulse.c -o C:\Users\Dell624\AppData\Local\Temp\build8877762333273966874.tmp\wiring_pulse.c.o
C:\Program Files\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\standard C:\Program Files\Arduino\hardware\arduino\cores\arduino\wiring_shift.c -o C:\Users\Dell624\AppData\Local\Temp\build8877762333273966874.tmp\wiring_shift.c.o
C:\Program Files\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\standard C:\Program Files\Arduino\hardware\arduino\cores\arduino\CDC.cpp -o C:\Users\Dell624\AppData\Local\Temp\build8877762333273966874.tmp\CDC.cpp.o
C:\Program Files\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\standard C:\Program Files\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp -o C:\Users\Dell624\AppData\Local\Temp\build8877762333273966874.tmp\HardwareSerial.cpp.o
C:\Program Files\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void store_char(unsigned char, ring_buffer*)':
C:\Program Files\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:98: warning: comparison between signed and unsigned integer expressions
C:\Program Files\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void __vector_18()':
C:\Program Files\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:127: warning: unused variable 'c'
C:\Program Files\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'void HardwareSerial::begin(long unsigned int, byte)':
C:\Program Files\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:368: warning: unused variable 'current_config'
C:\Program Files\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'virtual size_t HardwareSerial::write(uint8_t)':
C:\Program Files\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:467: warning: comparison between signed and unsigned integer expressions
C:\Program Files\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\standard C:\Program Files\Arduino\hardware\arduino\cores\arduino\HID.cpp -o C:\Users\Dell624\AppData\Local\Temp\build8877762333273966874.tmp\HID.cpp.o
C:\Program Files\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\standard C:\Program Files\Arduino\hardware\arduino\cores\arduino\IPAddress.cpp -o C:\Users\Dell624\AppData\Local\Temp\build8877762333273966874.tmp\IPAddress.cpp.o
C:\Program Files\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\standard C:\Program Files\Arduino\hardware\arduino\cores\arduino\main.cpp -o C:\Users\Dell624\AppData\Local\Temp\build8877762333273966874.tmp\main.cpp.o
C:\Program Files\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\standard C:\Program Files\Arduino\hardware\arduino\cores\arduino\new.cpp -o
Some warnings in the core libraries tend to appear from time to time.
However I see no errors there.
