J-M-L
April 19, 2021, 10:35am
21
you might miss the begins calls that are needed (?) with Sparkfun's library
in the setup() I would add
#ifndef __AVR__
Wire.begin();
if (! EEPROM.begin()) {
Serial.println(F("Error: No external EEPROM detected."));
while(true) yield() ;
#endif
You are right.
But I didnt forget those in my sketch. I just didn't post them here
PS: Whats the equivalent to
#ifdef __AVR__
for SAMD21 ? Could it be
#ifdef __SAMD21__
These are the defines the IDE passes to avr-gcc and avr-g++ when compiling for an Uno:
-DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR
Clock speed, IDE version, board name, and processor architecture. Not sure where __AVR__ comes from, but the IDE uses ARDUINO_ARCH_AVR as its tag. You can get these from the compilation output.
Not sure which specific ARM board you're using, here's the tags for a Zero:
-DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino MKRZero\""
So the tag is the IDE uses is ARDUINO_ARCH_SAMD.
Thanks very much.
I use my own custom based board. Similar pin configuration as the arduino zero.
I have been using AVR and VARIANT_ARDUINO_ZERO so far and they seem to work
system
Closed
August 18, 2021, 5:21am
26
