Hello,
Im using two sensor and all of them using interrupt
the first use juste pin 2 (imu6050) and the second (rotating encoder) use pin 2 and 3.
I don't have an other arduino board, so I've to keep my arduino uno and use both of sensors in the same time.
This is my code
#include <MPU9250.h>
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#include "Wire.h"
#define YAW 0
#define PITCH 1
#define ROLL 2
MPU6050 mpu;
// MPU control/status vars
bool dmpReady = false; // set true if DMP init was successful
uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
int a=0;
double t1;
volatile long temp, counter = 0; //This variable will increase or decrease depending on the rotation of encoder
int Compteur = 0;
float b,x=0,m=0;
// Définition des broches d'entrées
float dist=0,mm,dmm=0,pmm=0,amm=0;
Quaternion q; // [w, x, y, z] quaternion container
VectorFloat gravity; // [x, y, z] gravity vector
float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
volatile bool mpuInterrupt = false; // Indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
mpuInterrupt = true;
Wire.begin();
TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
Serial.begin(9600);//57600
Serial.println(F("Initializing I2C devices..."));
mpu.initialize();
Serial.println(F("Testing device connections..."));
Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
Serial.println(F("Initializing DMP..."));
devStatus = mpu.dmpInitialize();
mpu.setXAccelOffset(436);//556
mpu.setYAccelOffset(-1485);//1448
mpu.setZAccelOffset(914);//902
mpu.setXGyroOffset(47);//81
mpu.setYGyroOffset(-24);//-13
mpu.setZGyroOffset(-28);//-27/8
if (devStatus == 0) {
Serial.println(F("Enabling DMP..."));
mpu.setDMPEnabled(true);
Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0 : #pin2)..."));
attachInterrupt(0, dmpDataReady, RISING);
mpuIntStatus = mpu.getIntStatus();
Serial.println(F("DMP ready! Waiting for first interrupt..."));
dmpReady = true;
packetSize = mpu.dmpGetFIFOPacketSize();
Serial.print(F("DMP Initialization failed (code "));
Serial.print(devStatus);
Serial.println(F(")"));
pinMode(2, INPUT_PULLUP); // internal pullup input pin 2
pinMode(3, INPUT_PULLUP); // internalเป็น pullup input pin 3
//Setting up interrupt
//A rising pulse from encodenren activated ai0(). AttachInterrupt 0 is DigitalPin nr 2 on moust Arduino.
attachInterrupt(0, ai0, RISING);
//B rising pulse from encodenren activated ai1(). AttachInterrupt 1 is DigitalPin nr 3 on moust Arduino.
attachInterrupt(1, ai1, RISING);
if( counter != temp ){
dist=counter*1.95;
Serial.println (dist);
temp = counter;
// If programming failed, don't try to do anything
if (!dmpReady) {
return;
while (!mpuInterrupt && fifoCount < packetSize) {
fifoCount = mpu.getFIFOCount();
if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
mpu.resetFIFO();
Serial.println(F("FIFO overflow!"));
} else if (mpuIntStatus & 0x02) {
while (fifoCount < packetSize) {
mpu.getFIFOBytes(fifoBuffer, packetSize);
fifoCount -= packetSize;
mpu.dmpGetQuaternion(&q, fifoBuffer);
mpu.dmpGetGravity(&gravity, &q);
mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
t1=millis();
pmm=dist;
dmm=pmm-amm;
x=x+dmm*cos(-ypr[YAW]);
m=m+dmm*sin(-ypr[YAW]);
amm=pmm;
//Serial.print(dist);
//Serial.print("\t");
//Serial.print(amm);
// Serial.print("\t");
//Serial.print(dmm);
//Serial.print(x);
//Serial.print(m);
//Serial.println(-ypr[YAW] * (180 / M_PI));
//Serial.print(" ");
//Serial.println(mm,3);
delay(1);
void ai0() {
// ai0 is activated if DigitalPin nr 2 is going from LOW to HIGH
// Check pin 3 to determine the direction
if(digitalRead(3)==LOW) {
counter++;
}else{
counter--;
void ai1() {
// ai0 is activated if DigitalPin nr 3 is going from LOW to HIGH
// Check with pin 2 to determine the direction
if(digitalRead(2)==LOW) {
counter--;
}else{
counter++;
