How to reset Arduino DUE PWM?
Hi guys,
For several day I am trying to figure out how to reset Due PWM signal (to re-sync it with another signal).
This is my code:
    pmc_enable_periph_clk( PWM_INTERFACE_ID );
    // PWM STARTUP AND SETUP CLOCK
    PWMC_ConfigureClocks( _periodPWM*10/HIGH_LEVEL_LENGTH, PWM_FREQUENCY, VARIANT_MCK );
    // SETUP PWM FOR pin
    PIO_Configure( g_APinDescription[_txPin].pPort,  g_APinDescription[_txPin].ulPinType,  g_APinDescription[_txPin].ulPin,  g_APinDescription[_txPin].ulPinConfiguration);
    PWMC_ConfigureChannel(PWM_INTERFACE, g_APinDescription[_txPin].ulPWMChannel, PWM_CMR_CPRE_CLKA, 0, 0);
    PWMC_SetPeriod(PWM_INTERFACE, g_APinDescription[_txPin].ulPWMChannel, _periodPWM/HIGH_LEVEL_LENGTH);
    PWMC_SetDutyCycle(PWM_INTERFACE, g_APinDescription[_txPin].ulPWMChannel, 1);
        PWMC_EnableChannel(PWM_INTERFACE, g_APinDescription[_txPin].ulPWMChannel);
Following custom interrupt, I need PWM signal to restart it's cycle.
I tried resetting the PWM_CCNT counter to zero manually, but discovered it is read only.
I also tried to call
PWMC_SetSyncChannelUpdateUnlock(PWM_INTERFACE);
Any ideas?
Many thanks Meir Tseitlin
according to the ATMEL SAM3X8E datasheet (page 1050) you can re-enable the channel in order to reset the counter. I wrote this code to send one pulse on a channel. (for OneShot ESC on quadcopter) Please note, channel is only disabled at the end of its period after you call PWMC_DisableChannel().
void pwm_OneShot(uint32_t ch, uint32_t value){
  PWMC_SetDutyCycle(PWM, ch, value);
  PWMC_EnableChannel(PWM, ch);          //counter is reset here, pulse starts right now
  PWMC_SetDutyCycle(PWM, ch, 0);       //this stops pulsing until this function is called again (this gets written in the update register and does not affect the current pulse)
  PWMC_DisableChannel(PWM, CH);         //channel is disabled at the end of current period
