How to reset every pin when changing between functions?
I've been doing some code, I have four functions that I want to work when a condition is met, but I want to reset everything that is on the pins when I change between the. For example, if switch one is on and switch two is also on some leds turn on, and other actios perform too. If I change the condition and switch one is off and switch two is also off, I need LEDs to be off to perform other tasks but they keep on from the last function, so i want to reset every pin in the arduino to reset.
Here's my code:
//variables
int valorMap = 0;
int valorMapfoto = 0;
int valorFoto;
int valorPot = 0;
Servo servo_2;
int switch1;
int switch2;
int valorMotor;
int push1;
int push2;
int ledverde;
int ledroja;
int ledazul;
int pot;
//################PRIMERA FUNCION##################
//los dos switches estan apagados
int funcion1(){
//servo con potenciometro
valorPot = analogRead(A0);// valor del potenciometro lo lee del pin A0
servo_2.write(valorMap);//mueve el servo viertos grados
analogWrite(11, valorMotor);
//pushbutton1 enciende 2 led
if (push1 == LOW){//encender dos les con el primer psuhbutton
digitalWrite(13, HIGH);//encender led verde
digitalWrite(12,HIGH);//encender led amarillo
else {// apaga leds
digitalWrite(12,LOW);
digitalWrite(13,LOW);
//pushbutton 2 enciende 2 led
if (push2 == LOW){//encender dos les con el segundo psuhbutton
digitalWrite(10, HIGH);//encender led rojo
digitalWrite(9,HIGH);//encender led azul
else {//apaga leds
digitalWrite(10,LOW);
digitalWrite(9,LOW);
delay(10); // Esperar 10 ms
//################SEGUNDA FUNCION##################
//un switch encendido y el otro apagados
int funcion2(){
//apagar motor
digitalWrite(11,LOW);
//led verde con potencenciometro
ledverde = map(valorPot, 0, 1023, 0, 255);//va encendiendo el led verde
analogWrite(3,ledverde);//envia info
//led rgb rojo con fotoresistencia
analogWrite(6,valorMotor);//podemos reutilizar el valor motor para encender led rgb
//led azul con push button
if (push1 == LOW){//encender azul rgb les con el primer psuhbutton
digitalWrite(5, HIGH);//encender led azul
else {//apaga led azul rgb
digitalWrite(5,LOW);
//las cuatro leds deben estar encendidas
digitalWrite(10,HIGH);
//si el pushbutton se presiona se apagan las led
if (push2 == LOW){
digitalWrite(13, LOW);
//##################TERCERA FUNCION###################
//switch 1 apagado y switch 2 encendido
int funcion3(){
//apagar motor
//leer pines
int vfotof3 = map(valorFoto,0, 1023, 0, 255);//mapea cambios en fotoresistencia
int vfotof32 = map(valorFoto,1023,0,0,255);//mapea foto y cambia a rojo
int valorFotof2 = analogRead(A1);//leer la fotorresistencia
//si el push se presiona llevar a 0 grados
if (push1 == LOW){
servo_2.write(0);//mueve el servo viertos grados
//si el push se presiona llevar a 180 grados
if (push2 == LOW){
servo_2.write(180);//mueve el servo viertos grados
//controlar leds encendidos con potenciometro
valorPot = analogRead(A0);//leer el potenciometro
//encender leds en cascada
//si el pot menor encender led verde
if (valorPot < 256){
digitalWrite(13,HIGH);
//encender led verde y amarilla
else if (valorPot < 512) {
//encender led verde,amarilla y roja
else if (valorPot < 768) {
//encender todas las leds
else if (valorPot < 1024) {
//fotocontrola la iluminacion de rgb
//leer colores con analog read
analogWrite(3,vfotof3);//cambia a verde rgb
analogWrite(6,vfotof32);//cambia a rojo rgb
//######################CUARTA FUNCION#####################
//los dos switches encendidos
int funcion4(){
//apagar motor
//si el pushbutton esta presinado el potenciometro
//controla el led rojo rgb
if (push1 == LOW){
ledroja = map(valorPot, 0, 1023, 0, 255);//va encendiendo el led verde
analogWrite(6,ledroja);//envia info
else{
push1 == HIGH;
//si el pushbutton2 se presiona
//el potenciometro controla el led verdergb
if (push2 == LOW){
else{
push1 == HIGH;
//si la foto esta a mas de 50% el pot controla azul rgb
int valorMapfoto2 = map(valorFoto, 54, 974, 0, 100);//hacer map de 0 a 100 del resitor
//si el foto es mayo de 50%, poten controla azul rgb
if (valorMapfoto2 >= 50){
ledazul = map(valorPot, 0, 1023, 0, 255);//va encendiendo el led verde
analogWrite(5,ledazul);//envia info
//si no es mayor, no lo controlo
if (valorMapfoto2 < 50 & (push1 == HIGH & push2 == HIGH)){
valorMapfoto2 < 50;
//si es menor de 50 y algun boton esta presionado apagar led
if (valorMapfoto2 < 50 & (push1 == LOW or push2 == LOW)){
digitalWrite(3,LOW);
digitalWrite(6,LOW);
//setup
//definimos los pines(pullup messirve para los switches)
pinMode(A0, INPUT);
pinMode(A4, INPUT_PULLUP);
pinMode(A5, INPUT_PULLUP);
pinMode(A2, INPUT_PULLUP);
pinMode(A3, INPUT_PULLUP);
pinMode(11, OUTPUT);
pinMode(13,OUTPUT);
pinMode(12,OUTPUT);
pinMode(10,OUTPUT);
pinMode(9, OUTPUT);
servo_2.attach(2);
//Definir cada variable
switch1 = digitalRead(A2);
Serial.println(switch1);//switch 1 con pin A2
switch2 = digitalRead(A3);
Serial.println(switch2);//switch2 con pin A3
valorFoto = analogRead(A1);
//Serial.println(valorFoto);// fotoresistencia con pin A3
push1 = digitalRead(A4);//lee valores del primer pushbutton
push2 = digitalRead(A5);//lee valores del segundo pushbutton
//Funciones para mapaear posiciones y generar movimientos
valorMap = map(valorPot, 0, 1023, 0, 179);//mapea el ambio en el potencimetro
valorMotor = map(valorFoto,50, 1000, 0, 100);//mapea cambios en fotoresistencia
//funciones
if (switch1 == HIGH && switch2 == HIGH){
funcion1();
else if (switch1 == LOW && switch2 == HIGH){
funcion2();
else if (switch1 == HIGH && switch2 == LOW){
funcion3();
else if (switch1 == LOW && switch2 == LOW){
funcion4();
Hi @lpgp352
to post sketch, use tags </>
RV mineirin
Read the forum guidelines.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
www.arduino.cc/en/Reference/PortManipulation
for example you has green LEDs on pins (4, 5, 6, 7) and red on pins(8, 9,10, 11),
then for green
PORTD |= B11110000; to set on
PORTD &= ~(B11110000); to set off
for red
PORTB |= B00001111; to set on
PORTB &= ~(B00001111); to set off
enjoy & good luck
You could write a function:
void AllOff()
  digitalWrite(11, LOW);
  digitalWrite(12, LOW);
  digitalWrite(10, LOW);
  digitalWrite(9, LOW);
