Apologies if this is a really stupid question but I can't seem to find an answer...
All I want to do is to reset the entire Yun board! On the Uno, I press the reset button and the effect is powering off the board and powering it back on. However, when I press any of the reset buttons on the Yun it seems to only reset a particular IC so the effect isn't what I want. I even tried pressing all three at once...! My code consists of setup where I call three functions and loop where I do nothing. I want to use reset so that I can run the setup again and again to check the results I'm getting. I do not want to use loop() for this.
Has anyone got a solution for this?
Thanks,
Hester
P.S. When I open the serial monitor the board is also not reset so unless I open it up as soon as I plug the Yun in, I miss everything that's happening! I assume this is not supposed to happen...
# Put your custom commands here that should be executed once
# the system init finished. By default this file does nothing.
wifi-live-or-reset
boot-complete-notify
#reset-mcu
exit 0
uncomment reset-mcu will make reset arduino/mcu once reset cpu AR9331.
chestnutHester, that is a command line tool. In order to run it, you should connect to your yun using an SSH client. On windows, you should use putty
Once you see a "prompt" like the one shown in this tutorial, you can type the command suggested by sonnyyu and customize that file
